RX-8 N/A Engine Modification
Old May 27, 2010 | 01:27 AM
rtjhe's Avatar
I have 2008 Rx-8. My current mods are Re-amemiya header and Amuse catback exhaust, HKS Racing Suction. I want to have more HP on my car without having turbo. Only N/A Mods. What are the full lists that I could add to it?
Old May 27, 2010 | 01:40 AM
yiksing's Avatar
the giant tastetickles
The only significant hp gain as n/a is engine swap.
Old May 27, 2010 | 01:58 AM
Brettus's Avatar
Boosted Kiwi
BS - it has been proven time and again that the most significant hp gain is from the search engine .
Old May 27, 2010 | 02:58 AM
bse50's Avatar
#50
You should do a research on the board.
Power wise on a NA car you could switch back to the stock intake or get an AEM cold air intake, remove the catalytic converter or replace it with a sports one.
Better coils, fresh plugs, lightweight flywheel should also help. Get an accessPORT.
There's not much that you can do.
Old May 27, 2010 | 04:52 AM
tofu_box's Avatar
well that as listed above and some heavy engine work which will cost > then going FI.
If you wanna stick with NA and willing to pay $$ a whole new world opens up :P
Old May 27, 2010 | 06:05 AM
Huey52's Avatar
Registered Zoom Zoomer
Ported & polished and stroked & bored... well, at least ported and polished. But as cited potentially more costly than going FI.
The most cost effective NA enhancements are:
CobbAP with a MazdaManiac tune.
BHR Ignition system
High-Flo Cat (e.g. RP SuperCat)
eBay Chip (j/k)
Old May 27, 2010 | 08:40 AM
zoom44's Avatar
thread moved
Old May 27, 2010 | 08:52 AM
reddozen's Avatar
Gold Wheels FTW
Porting would cost you $500~$700, and the access port would cost you $600 with MM's tuning. That's a good bit less than FI, porting is pretty unproven ground until I can get my motor together and dynoed. Even mine wont stay NA unless by some ridiculous miracle I got 300+ HP (not happening).
I think the most you could hope for NA if you just had money to waste would be 250~260 HP tops. If you are realistically looking for more than about 220 HP, you'll need FI.
Old May 27, 2010 | 09:21 AM
pdxhak's Avatar
Official Post Whore
If you are porting a running motor then you need to add in the rebuild costs that go along with it.
Old May 27, 2010 | 11:44 AM
ken-x8's Avatar
So do you recommend that he swap in a search engine?
Ken
Old May 27, 2010 | 12:05 PM
tuning.
tuning
more tuning
Old May 27, 2010 | 12:06 PM
tubingchamp's Avatar
What mawd bug?
Ken
This is the best engine swap. I recommend it.
Old May 27, 2010 | 12:21 PM
CyberPitz's Avatar
Huge hole is huge
A Cold Air Intake would be where I start first. That will easily net you 15 to 20 extra HP.
You should get a new Cam. Maybe even some new valves, since the ones that come stock with the car are pretty brittle, and don't handle the extra HP your new CAI is going to add.
Putting Octane Booster in your gas tank *up to 103 Octane...* has been proven to increase 5 to 10 HP on the dyno. Very cheap extra HP if you're going to the drag strip.
With those starter mods, you should be getting to the mid to high 13's easy.
Old May 27, 2010 | 12:57 PM
Kafka's Avatar
I loled at the CAI easily net you 15 to 20 extra HP for the Rx8.
Are you joking, smoking, or doing both? :P
Old May 27, 2010 | 01:00 PM
Vlaze's Avatar
The Angry Wheelchair
Kafka, I'm pretty sure he's being sarcastic.....you don't put CAI with those gains nor octane booster with those gains and not be joking.......
Old May 27, 2010 | 02:53 PM
You need to enable that hidden VTEC option in the ECU. It adds another 30 hp to the Engine.
Get in your car, close your door.
Turn your key to on , do NOT start the engine, then off, repeat this for 3 times. (leave key in ignition)
Then open and close your door for another 3 times.
Turn your key to on again
Then turn your radio on (if you dont have stock head unit, put it back on) and tune it to AM 1480
Turn it off.
Then Turn your key to on and off again,
Get out of the car
Close the door,
Press lock on your remote
Go into your house, find that packet of Koolaid you brought when you were 5, mix it with warm water, add ice, drink it
Congratulations ! You just enabled that VTEC function in your ECU !
Now you can proudly tell the Honda guys that you just got another 30 hp by ...
VTEC JUST KICKED IN y0!
Old May 27, 2010 | 03:11 PM
mushkid's Avatar
Smile,It confuses people!
LMAO you guys are so mean!!! lol
you have a header which is good. just get your self a good mid pipe, a bhr ignition upgrade and a AP from MM and you will be more than satisfied.
and next time dude search!!! or else you will get teh sarcasm on ur threadz
Old May 27, 2010 | 03:23 PM
Turblown's Avatar
Boostin'
We only charge $299 for porting alone( no rebuild ).
http://www.turblown.net/store/index.php?productID=88
Its always been hard to make a LOT of power being n/a. Most guys go the nitrous route..
Old May 27, 2010 | 03:46 PM
TheWulf's Avatar
My 8 looks like a Smurf
Just out of curiosity what type of results do you usually see with mild porting?
Old May 27, 2010 | 04:10 PM
rtjhe:
why must you CONTINUE to always create multiple threads about the same thing?
Do you realize that is against the Forum Rules ?
Hopefully a mod / admin will assist.
Old May 27, 2010 | 05:18 PM
alnielsen's Avatar
Threads Merged
rtjhe, don't start multiple threads about the same subject. Read the RX8Club Rules.
Old May 28, 2010 | 07:25 AM
reddozen's Avatar
Gold Wheels FTW
And there you go... a cheaper option.
Old May 28, 2010 | 11:36 AM
california style's Avatar
Londons Yellow Peril
which search engine gives the most power?
Old Jun 1, 2010 | 08:58 AM
otakurx's Avatar
Rotorheaded Geek
I've heard from creditable sources that there isn't much that can be done as far as porting the Renesis engine due to the proximity of the water jacket. There is power in the N/A as shown by Eric Meyer and others but it takes time and often a little engineering.
PS: if ya want some real N/A power, P-Port the engine :p tho some re-working of the EFI system would be in-store or a switch to a nice Weber downdraft.
Old Jun 8, 2010 | 08:29 PM
04RX8man's Avatar
Rotary Powered Countryboy
just go FI you know u want 2
vapor2
Nov 3, 2020 03:38 PM
Eirulisse
Aug 15, 2015 12:34 PM
JPCZONE
Jul 21, 2015 12:02 PM
vssystemluba
Jul 19, 2015 04:16 PM
