rx8 greddy turbo kit install starting problems
Old Apr 24, 2010 | 03:27 PM
Less Than Fi<e's Avatar
Angry rx8 greddy turbo kit install starting problems
so i have the blue greddy emanage ultimate as my new computer an i followed the correct way to start it an it only cranks i unflooded it an it still just cranks..one issue i noticed is that my vacuum "that connects to the new air pump pressure hose greddy gives you" turns on an stays on for a while when i turn the key in the off position. what is causing that to happen an why wont it start.. i tried pull starting it an that didnt work.. i bought all new plugs as well
Old Apr 24, 2010 | 03:33 PM
Old Apr 24, 2010 | 03:34 PM
paulmasoner's Avatar
Asshole for hire
you cant use IMG tags on a file hosted on your PC. it has to be hosted on the web
Old Apr 24, 2010 | 03:37 PM
Old Apr 24, 2010 | 03:49 PM
i have all my pics commin to chk the set up
Old Apr 24, 2010 | 03:50 PM
Old Apr 24, 2010 | 03:51 PM
Old Apr 24, 2010 | 03:52 PM
Old Apr 24, 2010 | 03:54 PM
Old Apr 24, 2010 | 03:56 PM
Old Apr 24, 2010 | 03:57 PM
Get rid of the e-manage and you will have a much better time tuning and getting the car to work....
Buy an AP....it's a much more versatile way to run a Greddy Turbo on an RX-8....
do all my lines seem to be run correctly..i am only using the one vacuum line from behind the manifold an it T's off 3 different ways.. is that to much it goes to the actuator the bov an the boost harness sensor
Old Apr 24, 2010 | 04:00 PM
Search for " Greddy Turbo Fixes" and it will help you run the correct locations for the lines.....
The Blue E-manage will be the biggest of your problems....
i still coudlnt get it to start when i put the stock computer back in
Old Apr 24, 2010 | 04:01 PM
ok yea maybe ill have to get a new mep retune
Old Apr 24, 2010 | 04:02 PM
You could have easily flooded it.....try the deflood procedure with the stock ECU and it should start...
Have you changed the injectors?
Old Apr 24, 2010 | 04:11 PM
Old Apr 24, 2010 | 04:12 PM
Old Apr 24, 2010 | 04:13 PM
Old Apr 24, 2010 | 04:14 PM
no i did not change the injectors? should i have..i didnt think you needed to unless you were running high boost..should i change them
Old Apr 24, 2010 | 04:16 PM
Not needed..but it could have explained why the car wouldn;t have started...
Try the deflood...or pull it to clear out the crap and start it....
I'm not kidding about the E-manage..there are no good things to report by using it
Old Apr 24, 2010 | 04:17 PM
and if i need to change them what would u recomend that i get...brand an cc?
Old Apr 24, 2010 | 04:18 PM
really? why is that comp so messed
Old Apr 24, 2010 | 04:25 PM
Short answer...it doesn't work
