Humor Me, What's This Transmission Noise?
Old Apr 24, 2010 | 03:41 AM
Targatheory's Avatar
Throw out bearing. That's my answer.
It happens (or I only hear it during) when I'm in too high a gear for the speed I drive at.
Goes away when I step into the clutch...switch gears, try to save MGP etc.
It's a fairly obvious metallic whir.
Ok. Post it up.
Wait, I know what you want.
04 Rx8 6 speed manual.
Fidanza flywheel, ACT counterweight, Spec Stage 1 Clutch. Lithium grease on input shaft spline plus slave fork and throwout bearing. New throw out and pilot bearing lubed with said lithium grease. Talk.
Why do I only post when I should be out partying? I'm young...but care more about my car at these times...damn.
Old Apr 28, 2010 | 02:03 AM
extra Phil's Avatar
Does it almost sound like a fan or something that is rotating hitting something stationary? I only ask because i've been experiencing a mysterious noise for a while and can't figure it out either. Are you sure its coming from the trany?
Old Apr 28, 2010 | 03:39 AM
Jon316G's Avatar
Grasshopper
Not sure why you feel its the throw-out bearing when the noise goes away when you press the pedal in since that is when the throw-out bearing is actually being used (basically, you'll hear the bearing failure more with the pedal in).
I would lean more towards pilot or input shaft bearing.
Did this occur right after the pilot bearing (and everything else) was installed?
What did you use to press the bearing in with and is there any chance the end was crushed/deformed where it could affect the needle bearings?
And just for further information in case I'm wrong (always possible), how much pedal play do you have?
Should be 1/4"-1/2".
Old Dec 11, 2010 | 01:36 PM
mehidi@mail.com's Avatar
First rotary
i have the same problem. changed my oem to act clutch pad, pressure plate, release bearing but the still have my oem throwout bearing.
just changed the clutch (at a shop), every time i press the clutch pedal i here a noise like a helicopter but very very low volume. i goes away when a gear is engaged. also during the actual engagement, when i am letting the clutch go and pressing gas to engage the noise gets worse. the clutch has less then 5 miles on it. please help. the shop is saying thats just normal transmission noise but i do not believe them.
Old Dec 11, 2010 | 01:57 PM
wcs's Avatar
wcs
no agenda
Ok. Post it up.
Dude are you typing talking to yourself .....
That's spooky
<hides in the closet>
Old Dec 11, 2010 | 01:59 PM
Brettus's Avatar
Boosted Kiwi
, Spec Stage 1 Clutch. .
Clutches with heavier springs than stock do tend to cause noise at low rpm under load ....
Old Dec 12, 2010 | 11:03 PM
04RX8man's Avatar
Rotary Powered Countryboy
release bearing=throwout bearing
Shankapotamus3
Mar 14, 2021 03:53 PM
airlive
Jun 28, 2020 07:46 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
