water level sensor or air in the system?
Old Apr 5, 2010 | 08:44 PM
czar's Avatar
Almost boosted
So my issue is that at high rpm for any extended period my coolant light will come on, it seems temp independent and goes away if i clutch in and let it spin at low rpms few a sec. Would this be air in the coolant ? Ive tried bleeding the car, ive raise the front in and open the cap to bleed it out with no luck, turned on the heat to let possible air out of the heater core.
I know the sensors go bad sometimes but that wouldnt depend on rpm would it ?
Old Apr 5, 2010 | 08:49 PM
Put a bit more coolant in it
Old Apr 6, 2010 | 07:58 AM
czar's Avatar
Almost boosted
tried that it comes out the over flow if i add more
Old Apr 6, 2010 | 06:51 PM
waterproofone's Avatar
ROTORHEAD
Well I may have the answer..not sure. Not any coolant problems and I thought I needed more..the coolant tank was full but looked like it could use a little more..Then the next day at high RPM's the light would come on..but when i slowed down off the interstate it would go out. Coolant tank very full now. I drained some back to the level it was at before.. it only came on for a brief moment this time. Going to drain a little more and see. Like I said it never came on until I touched the damn coolant level. I should have left well-enough alone ya know?
I used a syringe to drain it..stick it down in the hole and suck what I needed out. Did this about 6 syringes full and is much better so far. If it happens again going to try a new tank cap first..then move on from there.
Old Apr 6, 2010 | 07:34 PM
The sensors suck...so it could easily be the problem
Check your lower rad hose as well.....( don`t ask )
If it isn`t low...don`t worry about it
Old Apr 6, 2010 | 09:37 PM
ROTORHEAD
what could be the deal with the lower hose? I did the upper ones but the dealer did the lower one since I couldn't get to it.
Old Apr 8, 2010 | 12:17 PM
czar's Avatar
Almost boosted
it makes me paranoid at times, and after abusive driving it tends to come on ~_~, guess ill unplug the sensor for now, tank is no where near empty so i am just going to guess a crazy sensor
drebbrnator
Dec 27, 2018 07:02 PM
HMSS013
Aug 28, 2015 03:02 PM
RXeckless
Aug 16, 2015 12:51 PM
Mr.Durden
Aug 12, 2015 02:21 PM
