Sounds like someone is playing pinball in my rotary
Old Mar 30, 2010 | 09:46 AM
NewBlueRx8's Avatar
Blue Balls
at low RPM's, just 2 weeks after I get it back from North Park Mazda
wtf.....
possibly engine running too hot and the oil is breaking down causing the temperature to rise (temp gauge flashed on)
any other suggestions?
2004 RX8 with 81k miles
Old Mar 30, 2010 | 09:47 AM
xun4gvn4everx's Avatar
True love is blue x2
For starters, did you call North Park Mazda back? What work did they do?
Old Mar 30, 2010 | 09:48 AM
laythor's Avatar
I zoom therefore I am.
either your radiator is overfilled (no head room causing air to not purge from the system) or your radiator is underfilled.
Either way check the overflow bottle and report back
Old Mar 30, 2010 | 09:49 AM
NewBlueRx8's Avatar
Blue Balls
this is at low rpms (like im at a drive thru window) and i hear it
I had the plugs, wires and coils replaced.
NewBlueRx8's Avatar
Blue Balls
ok im checking it now
Old Mar 30, 2010 | 09:55 AM
besides the sound, does the engine behave weird/bad?
Old Mar 30, 2010 | 12:00 PM
NewBlueRx8's Avatar
Blue Balls
i checked the coolant level and it is neither 2 high nor low
the engine bogs down sometimes as well at low rpms
Old Mar 30, 2010 | 12:03 PM
Bogging down at low rpm's is usually due to coils/plugs/wires. Since you just had your's replaced, maybe one of them is bad. I would try taking it back to them and have them check/replace the ones you have in there now. It has only been two weeks so it should be covered under a repair warranty.
Old Mar 31, 2010 | 08:54 AM
VOODOO8's Avatar
Hermitage Holdout
I like the pinball analogy
If few other quick checks being suggested don't offer a solution, you might want to search on another analogy - "marbles in a can".
Old Mar 31, 2010 | 02:15 PM
NewBlueRx8's Avatar
Blue Balls
also, while in drive idling at a red light i noticed white smoke coming from my tailpipes
Old Mar 31, 2010 | 02:19 PM
Galen Darkmoon's Avatar
I don't remember
Eight Ball Deluxe
Old Mar 31, 2010 | 02:25 PM
NewBlueRx8's Avatar
Blue Balls
Old Mar 31, 2010 | 09:40 PM
VOODOO8's Avatar
Hermitage Holdout
What was the temperature outside when you noticed this and was it shortly after starting the car up after having sat for quite a while?
If it was well above freezing temp outside and the car had been driven for a while and the engine was warmed up to normal operating temperature then see earlier post about "marbles in a can".
Old Mar 31, 2010 | 11:55 PM
Lebren's Avatar
RX8club group buy vendor
8 ball deluxe, you're referring to one of the best pinball games of all time! Second not as funny but here's a free "bump!"
Blue, Can you fill us in a smidge on what your 8 has gone through, including recent service? Im sure someone out there has experienced your symptom, a little detail goes a long way. welcome to the club!
Old Apr 1, 2010 | 08:34 AM
NewBlueRx8's Avatar
Blue Balls
it was about 60 degrees outside.
it was after my car sat for 3 hours
Old Apr 1, 2010 | 09:09 AM
OP, white smoke is a sign of a blown engine. You may want to take it to the dealership and get it checked out.
Old Apr 1, 2010 | 09:13 AM
NewBlueRx8's Avatar
Blue Balls
i knew the engine was blown when I had it towed.
Pep Boys told me that as Well as Ipac Mazda
North Park gave me the bs and said my engine is ok
those clowns.....trying to rip me for 567.00 hope the car goes out of warranty so I get stuck like chuck
thanks for all your help folks
Old Apr 1, 2010 | 09:18 AM
How many miles are on your car? If it is less than 100,000, then the engine is covered under warranty and will be replaced for free. But, you will have to pay ~$500 for the little things that Mazda doesn't cover. But, not a bad deal in the end since you do not have to pay for the new engine yourself.
Paul_Y
Sep 21, 2015 02:23 PM
GARCIAC951
Sep 10, 2015 07:17 PM
just1jack
Sep 9, 2015 04:45 PM
mattymack
Sep 6, 2015 10:33 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
