Air Pump Delete
Old Mar 22, 2010 | 10:48 AM
TX Air Pump Delete
Okay so I bought the Racing Beat Air Pump Delete cover thingamagingy and i removed the entire air pump assembly. The pump was failing (high pitch whine) and I don't have a cat so that is why I removed it.
The weird thing though is that when I had it unplugged before, I was getting the CEL for the air pump. Now that the entire pump assembly and wiring is removed I am not getting the CEL for the air pump or the usual CEL due to the mid pipe.
Could be a fluke, if not, then it's cool
My only complaint is that for $15.00 shipped you would think they could include two nuts, two washer, and two bolts.
Old Mar 22, 2010 | 11:01 AM
Fate710's Avatar
Super Low & Super Slow
When you did this, did you leave the resistor box connected and in the car? If so where did you mount it? I had thought about doing this and making my own block off plate, but wasn't sure.
Also what are you doing with that vacuum line that is not connected to anything now?
Old Mar 22, 2010 | 11:06 AM
The bracket for the air pump is two pieces, I removed the whole top piece with the pump and left the side piece that hold the resistor and supports the wiring harness to the ECU.
I left the resistor plugged in because I didn't know what it was for. The wiring for the pump was removed all the way back to the red plug on the fender.
I'll take some more pics later.
Old Mar 22, 2010 | 11:08 AM
Fate710's Avatar
Right on, yeah I wasn't sure what the resistor was for either, so I figured I'd make a custom bracket or something to hold it.
Old Mar 22, 2010 | 11:32 AM
I removed everything in Box #1, part #7.
I left everything associated with parts 11,12, and 13.
Old Mar 22, 2010 | 11:39 AM
MazdaManiac's Avatar
The resistor has to stay or the car won't run - its for the fuel pump.
Same with part #13 - that is the BARO sensor.
Old Mar 22, 2010 | 11:44 AM
TX
Yeah I didn't wanna remove **** randomly I left that side bracket there to support that sensor, hold the resistor and support the harness to the ECU. Grungepup and I were debating what type of sensor it is and he guessed right, haha.
MM, do you know what the sensor is on the front bumper support? I moved it due to my single cooler install and just wonder if where I put it is okay.
Old Mar 22, 2010 | 11:50 AM
Grungepup's Avatar
Oilfield trash
Old Mar 22, 2010 | 12:00 PM
laythor's Avatar
I zoom therefore I am.
can't you just unplug it and leave the whole thing in place?
Old Mar 22, 2010 | 12:08 PM
For some reason when I just unplugged it at the pump I got the CEL for it but when I removed it all and unplugged the whole harness, there is no CEL. But even if it comes back its no issue since I get the mid pipe CEL anyway. I just clear it each morning while my car is warming up anyway.
Old Mar 22, 2010 | 12:18 PM
Fate710's Avatar
may have to give this a go then today, I've got the steel to make my bracket, just need to do so.
Old Mar 22, 2010 | 12:33 PM
laythor's Avatar
all my cel's are masked by the AP, so i just went out an unplugged mine. had it replaced 2 months ago, now it's making the sound again. the dealership was trying to tell me the sound is normal... lol
Old Mar 22, 2010 | 12:45 PM
cornholio135's Avatar
SARX
I think you are talking about the one for the "Outside Amb Temp" sensor for the dash display.
Old Mar 22, 2010 | 01:10 PM
TX
I had the noise as well, it is not normal and has been discussed a lot. When I removed mine, sand poured out of it (I don't live near a beach).
i think so too, just couldn't find anything definitive about it (too lazy to search)
Old Mar 22, 2010 | 01:27 PM
Chris's Avatar
Turbo Member
dont you only get the high pitch sound at start up? I mean isnt that the only time the pump really does anything? I've had the high pitch with a cold (30degree) start but it goes away in several seconds. Ive also gotten a CEL for pump aswell. Dealership basically told me it isnt really needed to begin with (our dealership is actually good down here).
Old Mar 22, 2010 | 01:59 PM
laythor's Avatar
i have a catless midpipe, so it's completely useless to me.. unplugged it for now. might get around to capping it off.
Old Mar 22, 2010 | 02:00 PM
laythor's Avatar
oh.. and for the delete plate from RB, isn't that originially meant to be used on the header where you would already have bolts for it?
Old Mar 22, 2010 | 02:14 PM
Brettus's Avatar
Boosted Kiwi
Great place to mount a catch can as well
Old Mar 22, 2010 | 02:39 PM
lostmarine's Avatar
that plate goes where part 10 blots to the ex-mani, that is why there is no bolts or washers in the kit. you reuse the ones already there. 8P
Old Mar 22, 2010 | 03:06 PM
TX
Sitting in my garage my friend
Yeah you are right but I didn't wanna do that (PIA to remove) so where I have it, there are just two screws that screw into the threads valve on top so when you remove it you just have to put two bolts and two nuts on. I think where I did it is easier, and they should throw in the bolts for more options
Old Mar 22, 2010 | 03:10 PM
TX
Yes but getting to those looked like a PIA and this was easy.
Old Mar 22, 2010 | 09:07 PM
Fate710's Avatar
Just did this today, and I made it out of a piece of aluminum.
Old Mar 22, 2010 | 09:56 PM
TX
Cool, did you put it on the tube or the manifold itself?
Old Mar 23, 2010 | 12:40 AM
Fate710's Avatar
I just put it on the tube for now. I didn't feel like tryin to put it down on the manifold, I figure if I ever do put a header on the car, I'll change it then. The piece I did does what its supposed to do, but doesn't look pretty while doing it.
Haven't driven with it yet, even though I know it won't make a difference.
Old Mar 23, 2010 | 08:29 AM
you get the official seal of approval too, two nuts and a bolt all 10mm head, yeah that is just too hard so Ill just leave this pipe in here to radiate exhaust heat into the engine bay instead .... but when you remove it properly the bottom connection is two studs and you re-use the two nuts to mount the plate properly so why should they include fasteners that aren't required. Some people can screw up anything ...
