Cell after seafoam.
Old Mar 20, 2010 | 02:46 PM
Bigbacon's Avatar
2006 WB AT
Cell after seafoam.
I have a cell after doing this.
my friends OBD2 scanner can't read it, keeps saying Error. Cen-tech from harbor freight. Guess it does not have the CAN part.
I am reading that this is normal after doing the seafoam, is this true?
Some people say they got one while other didn't. I'm not sure what to do, I would like to know what the error is before going anywhere.
Is there anyone in NOVA who has a read that will work on the 8?
also, I had a TON of smoke with 30,000 on the clock.
Old Mar 20, 2010 | 02:54 PM
most likely it's due to you disconnecting the ESS.
should go away in a few drive cycles
Old Mar 20, 2010 | 02:56 PM
Bigbacon's Avatar
2006 WB AT
im guess autozone etc have readers that can read the errors though? I kinda just want to make sure. call me crazy. No cell before this, so I suspect you guys are correct unless for some reason my cat is clogged or something now.
Old Mar 20, 2010 | 03:45 PM
Bigbacon's Avatar
2006 WB AT
Any else still have sm9ke after like a 40 min drive? I had smoke feom the engine bay when i got home.
Old Mar 20, 2010 | 11:34 PM
jedi03's Avatar
i did seafoam, forgot dont have to seafoam intake since have carbon release already...just seafoam rest of motor, do the cel clear that is listed in forums an worked for me!
Old Mar 21, 2010 | 10:25 AM
Bigbacon's Avatar
2006 WB AT
what cel clear? I search for a while yesterday and found nothing.
kill the battery?
Old Mar 21, 2010 | 08:26 PM
jedi03's Avatar
turn key to on position, hit brake 20 times till oil pressure goes halfway then back, an hold trip meter while turning on till says testing...think that rite...i googled cel clear to find it...
WranglerFan
May 31, 2022 07:51 AM
