Motor shakes at stops.
Old Mar 18, 2010 | 06:47 PM
gunroc414's Avatar
novice at best
GA Motor shakes at stops.
When stopped my 8 shakes real bad under the hood. Only happens when stopped and in D or R. I've changed plugs recently and also inspected the motor mounts, they look fine. Could it be bad plug cables? I'm pretty sure it's not shields or something small like that as the whole engine assembly shakes together. PLEASE HELP!
Old Mar 18, 2010 | 06:48 PM
laythor's Avatar
I zoom therefore I am.
check the motor mounts, a known issue with some 8's
Old Mar 18, 2010 | 06:51 PM
Easy_E1's Avatar
Engine Mounts!!!!
Old Mar 18, 2010 | 06:53 PM
gunroc414's Avatar
novice at best
Ya I check the mounts, they look fine. There only 2 right?
Old Mar 18, 2010 | 06:56 PM
Easy_E1's Avatar
Looks can be deceiving. Right side is usually the first o go. It may look good on the outside but internally it is shot. I've owned two AT's. Ask me how I know about engine mounts.
Old Mar 18, 2010 | 07:03 PM
gunroc414's Avatar
novice at best
Ya, the sound seems to be strongest on the right. I've seen threads on DIY, thinking about giving it a shot. Anyway of knowing for sure before I buy a new mount?
Old Mar 18, 2010 | 07:09 PM
gunroc414's Avatar
novice at best
Here it is.
Old Mar 18, 2010 | 07:11 PM
gunroc414's Avatar
novice at best
I can't feel and shaking once I take off, just when sitting at stop.
Old Mar 18, 2010 | 07:19 PM
laythor's Avatar
plugs, coils, mounts, maf, fuel
pick your poison and start checking.
If your car's under warranty i'd still have the dealership check the mounts.. they can look fine but still be dead as disco.
Old Mar 19, 2010 | 04:33 AM
xsnipersgox's Avatar
One Shot One Kill
if you are not getting CEL, it is like 90% likely that it IS motor mount. and it shakes real bad cause tat is the only time you can feel it, make sure that your plugs are all tighten properly with the coils on properly, and if it's stlil going. it IS motor mount.
http://www.youtube.com/watch?v=wiI7-iXQj48
this is my car when i had unsecured plugs AND bad motor mount. clicking from plugs and shaking from motor mount.
Old Mar 22, 2010 | 01:06 PM
mbentley's Avatar
zoom-zoom
i had the motor mounts go bad on my 2005. took it to the dealership, pointed out the TSB (http://www.finishlineperformance.com...01-09-2062.pdf) and they replaced them under warranty.
Old Mar 22, 2010 | 01:14 PM
Mr.We$t's Avatar
Rx-8 the protege
If u push on the center of the rubber on ur mounts and urfinger sinks in ur mounts collapsed it should be hard in the middle
bosstin87
Oct 5, 2015 06:52 AM
Luke.s
Sep 30, 2015 05:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
