Harness lap belt mounts?
Old Mar 18, 2010 | 12:42 AM
Ideally I'd like to replace the two rear seat mount bolts with eyebolts and then connect the lap belt there with snap ends, but I can't find anything definite on eyebolts available with M10x1.25 threaded ends (the seat mount bolt thread size/type).
Saw some past posts that suggested that the Takata belt eyebolts fit here, but they only list M10 on their site, not the thread type. All the M10 eyebolts I've seen so far have 1.5 threads, not 1.25.
Anybody know of anything?
Old Mar 18, 2010 | 01:00 AM
alnielsen's Avatar
Have the head cut off the eye bolt and welded to the head of an oem bolt?
Old Mar 18, 2010 | 01:07 AM
I have excellent welding at my disposal, but wouldn't even consider that idea
it can be done other ways; brackets with holes etc, just that the eyebolt is clean if I can locate the right one
Old Mar 18, 2010 | 04:13 AM
StuttgartRX8's Avatar
Nurburgring Camera Whore
I have that same size on my skyline but I think the eye bolts are 7/16's or something around that range. I'll call the place I got them when the company in Texas wakes up.
Old Mar 18, 2010 | 04:56 AM
the 7/16-20 is the thread size/type where the OE belt mounts. While one is on the outer rocker rail, the other is on the inner OE seat rail, or in my case it was transferred to the aftermarket Kirkey seat as our rules require maintaining it.
Not ideal IMO, but in one thread someone used that eyebolt on the rocker rail for the outside point and then a bracket on the seat mount bolt for the inside point.
I'd prefer the M10-1.25 eyebolts if I can find them
Old Mar 18, 2010 | 05:27 AM
OK never mind then, I was in your same boat I couldn't find them either. When I got my car from Japan they had just welded a loop to the bolts.
Old Mar 18, 2010 | 11:17 AM
kjchristopher's Avatar
I haven't seen them either. Next step was looking for some sort of tab that would go under the bolt washer style and angle out enough to hook on to.
Old Mar 18, 2010 | 12:45 PM
Greenblurr93's Avatar
Sotally Tober
http://www.rud.com/en/produkte/ansch...isch-fein.html
Thats the ONLY M10x1.25 eye bolts i found
EDIT:
If you have a die you could make your own with unthreaded eyebolts
http://www.mcmaster.com/#eye-nuts/=69up9i
Old Mar 18, 2010 | 01:40 PM
$41 each in Tulsa, OK at some chain retailer, no reply from Takata but I think they may be 1.25 thread and only $9 each retail
Old Mar 18, 2010 | 05:22 PM
altiain's Avatar
Sparky!
Mark, I used standard metric eye bolts at the front bolt of the seatbelt "runner" on the outboard side, and the seat pivot bolt on the inboard side. I use clip in harness ends, although I usually leave the belt in the car, toss the outboard camlock end into the back floorboard, and tuck the buckle end down between the seat cushion and transmission tunel on the inboard side. It may not be 100% optimal, but it's worked just fine for me the last 3.5 years.
Old Mar 18, 2010 | 05:51 PM
BlueRenesis82's Avatar
Registered Tracker
Is it possible to run belts without totally messing up your interior? I would really like to run a dual purpose car.
Old Mar 18, 2010 | 09:22 PM
The local shop where I've been doing my serious work had the short 7/16"-20 eye bolts and I'm just going to make them work. It's not worth the usual hassle of trying to dig through dime a dozen worthless resellers who don't have the slightest f'ing clue about the products they're selling.
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Evan Gray
Nov 24, 2015 01:00 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
tommy26Germany
Sep 29, 2015 10:33 AM
