What premix is cat safe?
Old Mar 9, 2010 | 06:58 PM
prighello's Avatar
Okay before the search ****'s decend, I have read through most of the premix sticky which isn't exactly concise. Seems there are lots of opinions. So, what is cat safe for premixing:
TCW3?
JASO-FD?
ISO-EGD?
Does brand matter? Please don't just reply with...use idemitsu, because I am looking for something I can go buy in a local store rather than mail order.
Old Mar 9, 2010 | 07:24 PM
Brettus's Avatar
Boosted Kiwi
Go find something non marine (not TCW3) - suitable for two stroke motorcycles . JASO FD is good .
Old Mar 9, 2010 | 09:31 PM
ken-x8's Avatar
Is the stuff you buy in a hardware store, for use in lawnmowers and weed whackers, suitable?
Ken
Old Mar 9, 2010 | 09:34 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
Most are but they can be expensive, for quality (tested) ones.
The bottle is usually small for lawn equipment 2cy, and if you are premixing you tend to want to buy more quantity to offset the cost.
Old Mar 10, 2010 | 09:49 AM
Being impractical and brash becomes you ...
Old Mar 10, 2010 | 10:05 AM
the1jesster's Avatar
Trained true Killers
O no not again and again and again
Old Mar 10, 2010 | 11:03 AM
lepichichi's Avatar
I LuV mY Rotary....
^^ lol
I use idemitsu and i had no problems so far
http://mazdatrix.com/q-supply.htm
Old Mar 10, 2010 | 11:11 AM
invasion08's Avatar
^+1 with the Idemitsu Premix
Old Mar 10, 2010 | 11:13 AM
prighello's Avatar
Wow, most these replies are useless.
I'm starting to think no one really knows which is why I cannot find a straight answer on this forum.
Old Mar 10, 2010 | 11:23 AM
Snrub's Avatar
I'm fairly certain the answer for most pre-mixes is that they're not cat appropriate. It stands to reason that it might clog the cat over time.
Not to open a whole can of worms, but no one can produce solid evidence to prove that premixing is necessary for the street. This is just another reason not to do it. IMO premixing in a street car is in the same category as the ATF "solution", shoving a water hose in the intake, etc. They're not credible techniques to be used on a properly functioning street car. Focus on ensuring your MOP is functioning correctly.
Old Mar 10, 2010 | 12:09 PM
prighello's Avatar
Originally Posted by invasion08
WOW do a search. Many people have been using Idemitsu Premix for long time and have had no cat converter failures There is a whole thread on premix https://www.rx8club.com/series-i-tech-garage-22/gas-oil-premix-thread-99636/ start reading.
WOW is right...try to read the OP before replying. Notice the part where I state... "Please don't just reply with...use idemitsu, because I am looking for something I can go buy in a local store rather than mail order."
And the sticky…it’s over 100 pages and most of it isn’t useful.
Old Mar 10, 2010 | 01:52 PM
invasion08's Avatar
Premix is meant to burn and it burns clean and should have little affect on the cat converter. Use whatever premix you can get at your local autoparts store. I like Idemitsu since it is for rotary engines.
Old Mar 10, 2010 | 02:03 PM
laythor's Avatar
I zoom therefore I am.
since mazda has never released information on the testing of premix in the RX8 you are not going to find any hard data supporting it's use.
Anything out there is either anecdotal, conventional wisdom, or just plain vodoo.
Old Mar 10, 2010 | 07:02 PM
GeorgeH's Avatar
I asked Redline which of their 2-cycle oils they would reccomend for premixing in the RX-8, and the answer I got was that their "racing" 2-cycle oil would burn the cleanest and give the best protection & power.
I noticed that this premix is listed as TC-W3 allowable, so I specifically asked them if one of their non-TC-W3 oils would be easier on the cat.
The answer I got was "A TC-W3 oil is an ashless oil and as such shouldn’t have any ZDDP/phosphorous that would specifically degrade catalytic converter performance."
Furthermore, they said that their watercraft oil wouldn't be any harder on the catalyst than any of Redline's other 2-cycle oils, but that they would still reccomend the racing oil for the best protection.
Now, whether or not this means that all TC-W3 oils are cat safe I can't say. But it would appear that Redline achieves the TC-W3 rating in a way that doesn't produce some kind of nastiness for the cat. But then they use very high quality ester based oils and perhaps that's why - a dino based TC-W3 may still be a no-no.
Old Mar 10, 2010 | 07:04 PM
GeorgeH's Avatar
BTW, I asked Royal Purple the same thing, and the answer I got was that their 2-cycle oil (which is TC-W3 listed) should be much easier on the cat than the 4-cycle oil being injected by the OMP.
Old Mar 10, 2010 | 10:08 PM
xsnipersgox's Avatar
One Shot One Kill
just mail oder idemitsu, it's proven to be safe. takes a week or so, done.
Old Mar 11, 2010 | 11:00 AM
zoom44's Avatar
The lower the sulphur content the safer it is for the CAT. So look for one that is extremely low in sulphur
Old Sep 15, 2011 | 06:20 PM
dynamho's Avatar
I wonder how something can burn cleanly and still lubricate in an engine.
Sounds like magic.
Old Sep 15, 2011 | 10:34 PM
8upbad's Avatar
Jared
Nice thread lift! You would be surprised at the types of grease and oils they have and what they can do. I use a dozen different types on any given aircraft. That being said, you would also be shocked at how bad they can corrode and/or damage a part it it's not the correct type.
Old Sep 16, 2011 | 04:54 PM
dynamho's Avatar
Originally Posted by 8upbad
Nice thread lift!
Oh snap! I've been doing that a lot lately.
Old Sep 16, 2011 | 05:17 PM
8upbad's Avatar
Jared
That's ok. Just means you're searching and we all appreciate that.
Old Sep 17, 2011 | 05:20 PM
AAaF's Avatar
Sounds like magic.
Totally understand, I haven't got my full understanding of it myself.
How I was expecting it to work was that when gas is burned, oil is not completely burned, leaving some oil- damp for lubrication and work as a thermal barrier to a certain degree . When you look at a 2- stroke MC, you can see oil dripping out of the exhaust, something that is in conflict with these clean- burning statements.
But rich premixing helps with my hot- start problems, though.
Old Sep 17, 2011 | 05:25 PM
bse50's Avatar
#50
Valvoline has a lineup of cat safe 2 stroke oils, so do most of other brands. They're usually meant for scooters!
Old Sep 17, 2011 | 06:50 PM
8upbad's Avatar
Jared
2-cycle oil is made to burn and not leave anything behind. 4-cycle oil is the exact oposite, it's used in a totally different way. It doesn't blend with the gas and go into the combustion chamber.
Old Sep 17, 2011 | 08:25 PM
AAaF's Avatar
Yes, I see many people say that, but if it burns completely, what is the point of adding oil?(I see the purpose for a 2- stroke engine, where the mix lubricates everything inside crank house before combustion) There is no lubrication if there's no oil? So that means that it is only lubrication from intake- port to a bit after the spark- plugs...?
See my point?
Must subline that I'm not trying to be difficult, just educated.
mdl0209
May 23, 2019 05:46 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
FubarI33t
Sep 28, 2015 08:45 PM
