how do i put on hks grounding wire
Old Mar 2, 2010 | 01:07 PM
quicksilver34's Avatar
LIFE IS GREAT
I need help how to put on my hks grounding wire
I'm kinda new to yhe forums and I did my research
Before I pose this thread but I didn't find any thing and umm
My grounding kit didn't come with instructions so it suck
Please if yall can help me then that will be awesome
Old Mar 2, 2010 | 01:33 PM
JinDesu's Avatar
went back to srsly broke
Can you throw up a picture of the HKS grounding wire set? I might be able to give you instructions based on another set (assuming they look similar).
Old Mar 2, 2010 | 01:58 PM
LIFE IS GREAT
I will when I get home it has 5 wires on it
Old Mar 2, 2010 | 02:12 PM
JinDesu's Avatar
5 wires, and a round plate thing with multiple holes on the end and a center hole? It's the HKS Circle Earth system right?
Please see this thread: https://www.rx8club.com/series-i-tech-garage-22/my-grounding-kit-results-84924/
Especially this post: https://www.rx8club.com/showpost.php...9&postcount=58
That should be the best instruction you can get. I do not imagine the HKS system to be too different from the ebay one - just make sure you account for all the parts that came with your system.
When I did mine, I did each of those points in MazdaManiac's post except the coils. Mainly because it was a pain in the *** to reach.
Old Mar 2, 2010 | 02:24 PM
LIFE IS GREAT
Yes it the circle one
Old Mar 2, 2010 | 03:40 PM
halimsteven's Avatar
it's easy, i was asking the same question, but i figure it out.
1) first, you should ask yourself, where do you have your battery?
- mine is in the trunk, so i mounted the gold circle in the engine bay, and i ran one wire from (-) negative battery to the front to be connected to the CIRCLE PLATE.
- if it's in the engine bay, you should have the kit, so it can be attached to the negative battery, directly.
after this, you should be set for mounting it
2) you have to look for the grounding points
- run wires from circle plate to where ever the grounding points in your car. there is a thread to find out our main grounding points in our car.
that's it...you are set....be careful, don't put near any (+) current because if it's getting too close to +, then it's dangerous.
Old Mar 7, 2010 | 01:46 PM
LIFE IS GREAT
Man I can't find that post where put the wire at
Old Mar 7, 2010 | 02:12 PM
JinDesu's Avatar
What? What do you mean?
Old Mar 7, 2010 | 05:05 PM
ronx8's Avatar
zoom zoom!
is this a safe kit?
http://cgi.ebay.com/ebaymotors/P-7-W...Q5fAccessories
i read up a thread about someone purchasing a cheap grounding kit and it resulted in an electrical fire? I could be wrong.
Old Mar 7, 2010 | 05:42 PM
JinDesu's Avatar
Originally Posted by ronx8
is this a safe kit?
That kit should be safe. It's the same one I have.
Generally, if you think about it, you're merely reducing the resistance to ground. As long as you do not introduce a short, then you'll be ok. How can you introduce a short? If you put one of those wires over the positive terminal of the battery kit, like the guy you mentioned.
Old Mar 7, 2010 | 05:52 PM
ronx8's Avatar
zoom zoom!
ty for the info sir.
Old Mar 21, 2010 | 09:10 PM
perks11's Avatar
HEADTURNER
thanks guys
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Mr.Durden
Aug 12, 2015 02:21 PM
N0P1st0ns
Jul 30, 2015 09:45 AM
Stubbs
Jul 28, 2015 09:23 PM
stickmantijuana
Jul 19, 2015 10:33 AM
