Loose Plug Wire
Old Feb 27, 2010 | 01:38 PM
TheRedBaron's Avatar
Loose Plug Wire
I just changed my plugs today. When I was putting the plug wires back on I noticed the leading plug wire on the front of the engine isn't grabbing the plug like it should. If I let it go stays in place, but it never "clicks." Obviously I know I need to replace the wires, but for now whats the solution? I'll have to order the wires.
Can you just take a pair of pliers and squeeze the boot to make it fit better? Any tips? Thanks!
Old Feb 27, 2010 | 01:48 PM
Jon316G's Avatar
Grasshopper
Are you twisting the boot back and forth while pushing in?
There have been times I never heard/felt the click, so I reference the other connections to see if the spark plug's ceramic is equally visible.
If you see more ceramic with the "questionable" wire, you know its not on completely.
And do not use pliers on the boot with it still attached to the spark plug.
Old Feb 27, 2010 | 06:06 PM
lilring's Avatar
Finally a MT
You can take pliers to the wire but make sure it is off the plug. it is just a temp. fix though.
Old Feb 27, 2010 | 06:09 PM
That's a needle nose to be specific.
Old Feb 27, 2010 | 08:27 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
And be careful if you decide to squeeze it a little bit with needle nose. Actually, squeeze the boot just a pinch at a time with it off the plug!
Old Feb 28, 2010 | 09:04 PM
Thanks for the help. I was able to get it with no problem.
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
TeslaMSI
Dec 10, 2015 01:10 AM
GARCIAC951
Sep 10, 2015 07:17 PM
mattymack
Sep 6, 2015 10:33 PM
