Check engine....and others
Old Feb 10, 2010 | 08:23 PM
mlukaszm's Avatar
IL Check engine....and others
I have 2004 AT 32k rx8 .... i never had this problem before...this is my first winter with aem intake...and i think thats the problem. car is a little slower now i have less than 3/4 gas in my tank and i did 30 miles only...and the worst thing is. I started the car like always . just to heat up like everyday i didnt drive today. I heated up and i accelerate while i parked and check engine was blinking and shows up and it doesnt want to go back :D...and stay. what can be the problem. i had situatiol like that before with this intake but i was driving and it was blinking but it didnt was on... sorry for my english thx guys
Old Feb 10, 2010 | 08:27 PM
05rex8's Avatar
sold the 8... :(
blinking cel usually means misfire--might want to get the code read to make sure
change plugs, coils, and wires and that should take care of it
Old Feb 10, 2010 | 08:32 PM
mlukaszm's Avatar
I changed coils plugs sparks and wires 2k miles ago..... i didnt have this problem last winter but i had oryginal intake...maybe the air was to cold or something and intake took too much air or something
Old Feb 10, 2010 | 08:35 PM
05rex8's Avatar
sold the 8... :(
try this:
turn key to on position
push on the brake pedal as fast as you can, about 20 times
continue until you see the oil-p gauge needle sweep across
then take it for a spin
Old Feb 10, 2010 | 08:43 PM
mlukaszm's Avatar
ok ok i will try....what about gas milage ? its taking to much gas. what can i do about it..
Old Feb 10, 2010 | 08:50 PM
05rex8's Avatar
sold the 8... :(
try the pedal thing first
it resets the e-shaft position sensor
it may solve your entire issue
its worked for me in the past
Old Feb 10, 2010 | 08:55 PM
mlukaszm's Avatar
OK so what i did i turn key to ON position... i pushed brake pedal very fast like 20 times....and i started up and still nothing..
What im gonna do is take battery to my home for a night...it should reset computer
Old Feb 10, 2010 | 09:14 PM
@!!narotordo's Avatar
FLAME ON!
Make sure the spark plug wires are connected right IE;
1st coil 2nd coil 3rd coil 4th coil
Leading Trailing Leading Trailing
Also make sure the spark plug wires are on tight! if they dont make that pop sound they can come lose and you will not get a good spark=shutter rpm brake up ect.
Have your local autoparts store like autozone or checker ect check the code for you and tell us what the code is. Then we can go from there or tell you right off the bat whats wrong.
Hope that helps.
Old Feb 10, 2010 | 09:16 PM
mlukaszm's Avatar
everything was good...but after car get heat up. i accelerate little bit more 6500-7000 rpm. and after that check engine show up
Old Feb 10, 2010 | 09:29 PM
05rex8's Avatar
sold the 8... :(
did you see the oil-p needle move to the center when you did this? if not do it again
Old Feb 10, 2010 | 11:28 PM
mlukaszm's Avatar
it didnt go to the center...i tried but it just couldnt....what if will not go again ?
Old Feb 11, 2010 | 09:27 AM
05rex8's Avatar
sold the 8... :(
You're not doing it fast enough then.
Old Feb 11, 2010 | 09:28 AM
mlukaszm's Avatar
So i should press brake pedal like super super fast ? , because after few moves its harder and harder to push it...
Old Feb 11, 2010 | 11:17 AM
Solidtrance's Avatar
All you have to do is tap the pedal. i hope you are not trying to push it all the way in. Do it on ayour garage and look in the rearview. As long as you see the brake light lighting up you are hitting it hard enough. No need to press the pedal any harder.
Old Feb 11, 2010 | 11:33 AM
05rex8's Avatar
sold the 8... :(
^what he said
Old Feb 11, 2010 | 12:48 PM
mlukaszm's Avatar
alright.. i install battery again and looks fine....hope will be like that later too thx guys
LB2739
Jul 9, 2019 02:25 AM
Danield97
Oct 10, 2015 05:58 PM
Forevermore
Sep 20, 2015 01:04 PM
Vedivan1
Sep 18, 2015 12:39 PM
Irvinb16
Sep 11, 2015 10:27 PM
