clutch pedal
Old Feb 3, 2010 | 03:44 PM
Rotary REVolution's Avatar
Life's short, REV IT!
clutch pedal
just wondering if anybody has had any experience with this product: http://raceroots.com/index.php/produ...t-bracket.html - pros/cons of it, worth it or not, etc.
Old Feb 3, 2010 | 04:09 PM
There are a lot of us with this....
I think it is a great fix for the problem....
Others say...weld the stock bracket
Personally...Mine's been in for 2+ years....and the bracket is solid as a rock
Old Feb 3, 2010 | 04:31 PM
TopGear8's Avatar
mkuhnracing.com
^Agree with dan. I've had this bracket on for a year now and its great. Once the squeaking started I was always scared I was going to break my clutch pedal, especially at the track. After installing there is no squeak, and the clutch pedal is much more firm. Definitally a must have because these clutch pedals will break eventually.
Old Feb 3, 2010 | 04:59 PM
DeViLbOi's Avatar
The devil made me do it
I think the biggest difference between this product and the weld method is the availability of a reliable local welder you can trust. This product is a great alternative for those that don't have a local welding option that they can trust.
Old Feb 3, 2010 | 06:04 PM
kersh4w's Avatar
Hit & Run Magnet
its worth it.
Old Feb 3, 2010 | 08:45 PM
05shinka's Avatar
Bad Company, Till I Die
Do it.... much better feel to the pedal.
Old Feb 3, 2010 | 09:01 PM
LGukas's Avatar
one more time... grate product.
Old Feb 3, 2010 | 11:32 PM
thanks to all for the helpful info. i imagine i will be purchasing and installing this product in the very near future
Old Mar 9, 2010 | 03:40 PM
silverbullet05's Avatar
Ordered one myself. Had Mazda weld it for a quick fix, but has started squeaking again. Installing it the day it gets here!
Old Mar 9, 2010 | 03:41 PM
Meh, its okay, installed it with another member, seems like overkill.
Old Mar 9, 2010 | 03:47 PM
Brettus's Avatar
Boosted Kiwi
definately overkill but a good alternative if you don't have access to a welder
Old Mar 9, 2010 | 03:56 PM
Solidtrance's Avatar
Its a great piece and definitely worth the money and time to install. I can't imagine just welding the pedal assembly would be anywhere close to as strong as this bracket makes it.
Before:
A few of the finished product:
Might be overkill, but it surely wont break. Took about 4 hr's to do and I am pretty slow with DIY's.
Attached Thumbnails clutch pedal-rr-clutch-brace-1.jpg   clutch pedal-rr-clutch-brace-2.jpg   clutch pedal-rr-clutch-brace-3.jpg   clutch pedal-rr-clutch-pedal-brace.jpg
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
