View Full Version : Lights don't flash on alarm arm/disarm..
Reeko
01-20-2004, 02:48 PM
Guys,
In the last week, my lights stopped flashing when the alarm arms/disarms.
Checked that all the lights do work, also the horn does sound, so I am at a loss what to look for next.
Any quick thoughts (especially anyone with a wiring diagram?) so I don't need to leave "My Precious" at the shop...
Rick
eccles
01-20-2004, 03:05 PM
Check your trunk. If either door, the hood, or the trunk is ajar, the alarm will not arm although the doors will still lock.
I had the same thing happen to me, and it turned out that I must've popped the trunk without realising it, probably by pressing the wrong button on the remote.
Reeko
01-20-2004, 03:21 PM
I will check, but...
The alarm seems to arm, the horn beeps when I press the remote.
eccles
01-20-2004, 03:29 PM
Trust me, I had exactly the same symptoms. It seems that the beep merely confirms that the doors are locked, while the flash indicates that the alarm is armed.
ELX13
01-20-2004, 03:44 PM
ditto eccles.
i had the EXACT same thing happen to me. turned out i was driving around with my trunk open all day! ;)
Reeko
01-20-2004, 04:37 PM
Thanks,
You were right. Weird, I thought the horn was for the alarm.
Trunk has been partially open, but not visually noticable.
Thanks Again.
r0tor
01-20-2004, 06:08 PM
Originally posted by ELX13
ditto eccles.
same thing here too... I think mine was open for a good 2-3days :o
eccles
01-20-2004, 06:10 PM
You're most welcome.
This is actually one of the things I hope they fix on next year's model - because the trunk doesn't swing open of its own accord, it's all too easy to be driving around with the lid not secured. There really ought to be some form of warning on the dash.
my10ae
01-20-2004, 06:17 PM
Hey all:
Thought I'd chime in here. I had a very unusual thing happen to me on Sunday. I went to lock my doors and every time I did, the alarm (read that as panic) went off...lights flashing and horn blowing. I checked the trunk, it was closed. I could hear the locks locking when I hit the key fob. Come to find out after some troubleshooting, I find my lock level on the driver's door "pulled" out further than usual. Usually the lock lever angles out showing that the door is unlocked. What was happening when I went to lock and arm the car, the door tried locking itself and could not so it set the alarm (panic) off. I just pushed the lock lever back to its original position and all is good.
Just something I'd thought I'd pass along to everyone if this should ever happen to them.
