MS exhaust 2.5? Little confused...
Old Jan 24, 2010 | 07:59 PM
RX8sd's Avatar
Ok...I'm confused and I might have a prob. My rx8 had MS exhaust already on it when I bought it. I thought for some reason that it was a 3.0...but I've done some reading on here lately and I've been told that it's a 2.5. IS this true? Another reason I wanna know is I ordered and had a RB dual midpipe installed and I'm pretty sure that thats 3.0. I have sputtering now in the high rpms and no advance in power and I'm wondering if thats the reason why......difference in size causing exhasut leaks. Can anyone out there set my mind straight on this?
Old Jan 24, 2010 | 08:12 PM
8 Maniac's Avatar
Senior Member
That's not the cause behind your power issues. A clogged cat would be the most likely exhaust component that could cause power issues but it's not guaranteed to be an exhaust problem. You could need new coils or plugs or could be a few other issues.
Old Jan 24, 2010 | 08:25 PM
AJ's Shinka's Avatar
Enthusiast
It is true.
Old Jan 24, 2010 | 09:24 PM
RX8sd's Avatar
Originally Posted by AJ's Shinka
It is true.
You saying it's true to what I said about the sizes being different and causing the power loss...or you sayin true to what 8 Maniac said. I would assume even if it's not the cause...that I should still put the stock cat back on.
Come on guys...I need a definet answer if you know. It didn't do the sputtering till I put this thing on and my coils and plugs are brand new.
Old Jan 24, 2010 | 09:46 PM
Nemesis8's Avatar
Bigus Rotus
...Another reason I wanna know is I ordered and had a RB dual midpipe installed and I'm pretty sure that thats 3.0....
All Racing Beat exhaust components utilize stock flanges. They neck down to 2.5" at the flanges. PhillipM got 268 HP out of a 2.5" exhaust, so your power loss is not related to the size restriction.
Old Jan 24, 2010 | 10:07 PM
rodjonathan's Avatar
silent assasin
the only component of the exhaust that may be causing power loss is the cat
Old Jan 24, 2010 | 10:13 PM
RX8sd's Avatar
hmmm interesting.... well I guess it was just installed wrong or someting. Leaks somewhere are the only thing I can think of
Old Jan 24, 2010 | 10:46 PM
RX8sd's Avatar
or at least I hope thats what it is
Old Jan 24, 2010 | 10:48 PM
8 Maniac's Avatar
Senior Member
No. The only reason you'll have noticeable loss of power is if the flow is blocked. An exhaust leak will not cause a noticeable loss in power. If there is an issue with your exhaust, it will most likely be the catalytic converter being clogged, meaning it needs to be replaced. It's not a matter of proper installation.
Old Jan 24, 2010 | 10:51 PM
Pico's Avatar
It's Complicated
+1
Your cat is gone...
Your be a happier guy when you install the mid pipe-- believe me
Old Jan 24, 2010 | 11:03 PM
RX8sd's Avatar
Originally Posted by Pico
+1
Your cat is gone...
.........the mid pipe is already on pico........thats what I'm afraid is leaking and I thought it was due to different sized piping but everyone else here thinks different and I beleive them. So this leaves the only option of leaks somewhere at the flange. Only thing I can think of since plugs and coils are new. Grrrr very frusterating...
Old Jan 24, 2010 | 11:08 PM
RX8sd's Avatar
Sorry I just noticed your reply....and I have no idea what to think now. There is no cat now so I have absolutely no idea what could be resricting the airflow
Old Jan 24, 2010 | 11:14 PM
RX8sd's Avatar
my oem coils were changed about 6k miles ago....and my plugs were changed about 2 months ago....so it cant me that. Damnit
Old Jan 28, 2010 | 05:03 PM
epikeddie's Avatar
Try resetting the ess profile. Stomp rapidly approximately 20 times with the key in the on position (but do not start the car). You'll see the oil pressure gauge needle do a half sweep. Turn the key to off position, then back to on and start the car.
High RPM breakup (after I installed something new) was usually cured by doing this.
Old Jan 28, 2010 | 09:45 PM
8 Maniac's Avatar
Senior Member
in a worst case scenario, you could be having more severe engine issues.
Old Jan 28, 2010 | 11:31 PM
tiltmode43's Avatar
OMGITM!
Because it is relevant,
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
arexatemate
Oct 28, 2019 08:16 AM
mdl0209
May 23, 2019 05:46 PM
Jb4ker96
Sep 27, 2015 10:06 PM
