a/f wideband install question
Old Jan 17, 2010 | 12:19 PM
KrumbZ's Avatar
1.3L of Fury
what is the best way to route the wideband sensor? do i have to hook it up to the midpipe? thanks
Old Jan 17, 2010 | 12:51 PM
You need to hook it up to the exhaust someplace
The biggest issue is protecting the wiring from the heat..so be careful to secure it in as cool a location as possible to keep it from melting. You can run it into the engine compartment...or into the cabin......depends where you put your controller, and if you want to drill a hole or not..
Old Jan 17, 2010 | 12:56 PM
gregs's Avatar
Pull My Finger
easiet place to place it would be in the cat monitor bung if you dont want to weld a additional 02 sensor bung
Old Jan 20, 2010 | 11:15 AM
PhantomRX-8's Avatar
Bad Ass
^^ What he said. I have a catless midpipe so I just took the 2nd o2 sensor out and put the wideband in there. Then had the wire follow the same path as the fuel line/brake line, then put it over the tranny and entered the car in the hole i drilled behind the windshield wiper fluid tank. Would never know its there.
Old Jan 20, 2010 | 11:38 AM
NgoRX8's Avatar
I routed through the shifter opening. Works well.
Old Jan 20, 2010 | 01:09 PM
05rex8's Avatar
sold the 8... :(
this is the by far the easiest way
Old Jan 20, 2010 | 06:33 PM
chickenwafer's Avatar
Nope
What he said. Since you have the AP with the Cat CEL turned off just put the WB02 in the cat pipe and leave the OEM secondary sensor out.
Old Jan 20, 2010 | 09:46 PM
RX8 dood's Avatar
With the OEM sensor out, you can run the car daily like this? With no problems?
Old Jan 20, 2010 | 09:50 PM
05rex8's Avatar
sold the 8... :(
yup, that's how I run mine
Disconnected the O2 sensor for the cat and replaced it with my wideband sensor in my catless midpipe
Old Jan 20, 2010 | 10:33 PM
NgoRX8's Avatar
that's what I do with mine now with my racing beat dual resonated. although I do have an extra bung welded on my hks catalyzer before the cat for when I use it.
Old Jan 21, 2010 | 04:05 AM
RX8 dood's Avatar
So you just disconnect the O2 Sensor at the connection, leave the connection empty and run the wideband directly to the gauge? or does it plug into stock o2 sensor location?
Old Jan 21, 2010 | 11:33 AM
NgoRX8's Avatar
you can leave the rear o2 sensor disconnected and run an aftermarket wideband o2 sensor in its position. you will however, get a CEL for the rear o2 sensor if you aren't using the AccessPort. nothing wrong just an annoying light.
Old Jan 21, 2010 | 12:26 PM
Brettus's Avatar
Boosted Kiwi
what them fellas said
Old Jan 21, 2010 | 02:03 PM
hakuna matata!
no, you run the harness for the aftermarket wbo2 to the controller/gauge. the oem harness connector you should cap to protect it..
Old Jan 22, 2010 | 01:39 AM
RX8 dood's Avatar
great info guys, thanks, although wasn't my thread but seemed to go along with the original post
mr. GrandGame
Sep 9, 2025 10:41 PM
RicerX1
Jan 11, 2016 05:59 PM
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
dancingdan42
Aug 19, 2015 09:29 AM
MolecularConcept
Aug 5, 2015 04:43 PM
