Wideband 02 sensor/AFR gauge
Old Jan 13, 2010 | 10:57 AM
Frosty288's Avatar
n0 pants
Just curious, can the innovate DB read the stock wideband, instead of buying an additional wideband 02 sensor?
Old Jan 15, 2010 | 12:20 PM
Frosty288's Avatar
n0 pants
superbump
Old Jan 15, 2010 | 12:22 PM
MazdaManiac's Avatar
Nope.
Old Jan 15, 2010 | 01:37 PM
Salamanth's Avatar
You like the LM-1 sensor MM?
Have you had any luck getting it to log via the Accessport?
On a related note, any tricks concerning resolving the "lag" experienced with AP logs?
Old Jan 15, 2010 | 01:45 PM
Works for me.
You mean via the AccessTUNER software? No problems - it works perfectly.
Lag?
Old Jan 15, 2010 | 05:19 PM
kersh4w's Avatar
Hit & Run Magnet
it logs what.. 6 times per second iirc.
i have not seen any lag.
Old Jan 15, 2010 | 05:26 PM
Up to 12 times a second, depending on how many parameters you have on.
2 or 3 times a second is actually enough resolution to tune. Anything that seems to happen faster than that in a sensor report is essentially noise, anyway.
Old Jan 16, 2010 | 04:15 AM
thewird's Avatar
Use the LM-2. Its smaller, nicer looking, and newer . I have one and and use it to tune cars since it has the cigarette lighter thing for power which makes it very portable
thewird
Old Jan 18, 2010 | 09:19 AM
arghx7's Avatar
sample rates certainly aren't the accessport's fault... it's limited by the ECU itself
cliffkemp
Dec 24, 2024 10:48 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
JantzenRX-8
Oct 4, 2015 11:30 PM
