Removing metal cap in the fog light?
Old Jan 9, 2010 | 04:01 PM
NiGhtRx8er's Avatar
Does anyone know how to remove the metal cap located inside the foglight, doing so, would it make it brighter? thanks
Old Jan 9, 2010 | 09:48 PM
secret8gent's Avatar
the enemy in the mirror
uh i read a thread on this somewhere, can't remember where off hand
basically the guy just took it out carefully with a set of pliers (crushing and twisting and cutting it)
considering it can't be a perfectly efficient reflector I'm sure it would gain some brightness, but moreover the light just comes out with a different focus...
Old Jan 9, 2010 | 09:53 PM
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-how-remove-foglight-housing-bulb-reflector-176299/
found it
also i'm assuming you'd do this for looks, not to improve the performance of your fogs...
Old Jan 9, 2010 | 10:20 PM
Alexb's Avatar
desperately needs a drop
aipex8 did it to make his LED's fit. I wouldn't do it unless you are trying to do something like that. The purpose is to not distract on-coming drivers.
Old Jan 10, 2010 | 09:03 AM
NiGhtRx8er's Avatar
thanks, I figured removing it would make it brigther but Im sure it serves a purpose...
Old Jan 10, 2010 | 02:00 PM
It won't make it brighter really...it will increase the glare a lot though. The blocker removes the scatter reflection from the bulb
Old Jan 12, 2010 | 11:33 PM
lopezian2004's Avatar
Master Shr3dd3r
I could never get the thing out with pliers. Ended up just using the fog light housing to make HID projectors.
Good luck anyway!
Azki23
Jun 27, 2018 03:48 PM
TeslaMSI
Dec 10, 2015 01:10 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
rxwilly8
Sep 2, 2015 02:42 PM
wayloco
Sep 1, 2015 09:03 PM
