Help help rx7
Old Jan 4, 2010 | 09:32 AM
PENTECH's Avatar
Help help rx7
Before i start HAPPY NEW YEAR .... MORE POWER TO ALL RX OWNERS
Im back now i need someone to help me out.... Im fixing a RX7 right now. i tried to diagnose it but the problem my scanner can't read it just found out it's 97 model using old/ original 17 pins. also i found out beside said oins there another pins it's eight pins.
How can i diagnose this thing? actually i felt so bad and so dissappointeted when the told me he paid to much before from other shop. The shop charge him too much and he said he can make his twin turbo RX
7 very fast, etc.
here's the FF i found what they before.........
they opened the whole engine so they can can adjust everything BLa..bla.... to make it strong
now the problem the RX had very very rough idle, so rich gas smell, and cant accelerate
what can i do or any idea can share what are the problem, etc??
HAPPY NEW YEAR thanks...........
Old Jan 4, 2010 | 09:46 AM
rotarygod's Avatar
We didn't have an RX-7 in the US after 1995 so what may be on the car that you are working on may not be and probably isn't the same as the cars we had.
What all has been done to the car? Can you list the symptoms a bit better? Is it flooding? Does it have a standalone ecu? Are the plug wires hooked up correctly? Is the ignition system working properly? Is there good fuel pressure? Is there a leaking fuel injector?
You get the idea. List all you know about it and then tell us what you've checked so far.
Old Jan 5, 2010 | 04:57 AM
PENTECH's Avatar
the main problem before i touch this car there's already someone tried to tuned it. the owner told me he wanted to increase the horse power so....
> first he told me the past mechanic touched the engine opened the whole engine, mechanic said he can adjust the rotary/ etc <inner parts> so it can increase hp.... so i was shocked make me wrong for me i dont believe you have to open /calibrate inner parts of wankel engine i believe it's already designed for power, so the only way to increase more power bigger turbo, racing box, filters, etc
> symptoms- idle are rough, exhaust are to rich, every time you drive it there's no reaction
> consume gas too much
>imagine V8 old school camaro sounds like that and the body shakes <when the car is in neutral only/ park only>
Hope this one i can fix it soon actually they're were four groups so once i fixed this one others to follow
Old Jan 6, 2010 | 10:44 AM
MAZMART "6"'s Avatar
Android Army
Sounds like the motor was ported. What kind of porting, who knows. But from the what you are saying about the idle & fuel, sounds like a bridgeport. Unless you can get more info from the owner or mechanic, it will be hard to help you.
-Sheldon.
Old Jan 7, 2010 | 03:48 AM
PENTECH's Avatar
help help
-Sheldon.
thanks for the reply ....is it possible rotary to be ported? if ever the dynamo inside the engine will be mis match?
Old Jan 7, 2010 | 07:34 AM
Android Army
Have you worked on a Rotary car before, or is this your first?
-Sheldon.
Old Jan 7, 2010 | 10:59 AM
CyberPitz's Avatar
Huge hole is huge
This will help you with porting knowledge...
http://www.mazdarotary.net/porting.htm
It's VERY possible to port while being very good at giving additional HP.
Old Jan 7, 2010 | 04:29 PM
Poop's Avatar
Heh123
there is always blue printing the engine =O What do you mean by rough idle? does it go up and down alot? are the spark plugs changed? also, you should do a compression check on the engine.
Old Jan 8, 2010 | 05:24 AM
PENTECH's Avatar
hi
-Sheldon.
yes but honestly speaking i never tried to open it. i believe don't have to open it, not like other engines with pistons and head cylinder i used to open it to add more HP, usually i only upgrade turbo and programmable box.
i believe rotary have nothing to do inside if there some can do maybe you can give me some tips.
By the is it true there's no pistons on it???
Old Jan 8, 2010 | 05:27 AM
PENTECH's Avatar
thanks now you gave me an idea i can use a compression test on it. is it the tool for piston type engine?
rough idle.... imagine an american V8 all out set up it looks like that it rattle whole body. but it goes ups/ down yes plugs are new.
i really wanted to help this group. to make there rx runs in good condition
Old Jan 8, 2010 | 08:20 AM
Android Army
Oh my gosh......
Old Jan 8, 2010 | 09:41 AM
Martyr#1's Avatar
KS
This thread is full of fail.
Old Jan 8, 2010 | 09:46 AM
dozer's Avatar
on his 3rd rx8
^agreed
Old Jan 8, 2010 | 10:07 AM
rotarygod's Avatar
It really sounds like a tuning issue. Find a competent rotary tuner and see what they can do with it. Don't just assume it's an engine issue.
Old Jan 9, 2010 | 09:24 AM
PENTECH's Avatar
i agree but o have no idea what the first mechanic he done on it
Old Jan 9, 2010 | 09:25 AM
PENTECH's Avatar
hey bro thanks so much you gave an idea
Old Jan 9, 2010 | 09:30 AM
PENTECH's Avatar
hey dude im just being frank here it's good some people help me out
im not 100% perfect here when it comes to rotary that's why i registered here
regarding the pistons some people says there's a pistons on it, but most people i talked there's no pistons on it . that's why i want to know the truth.
im here to help other people who loves RX's so i want also to share what i learned from you guys
Old Jan 12, 2010 | 09:33 AM
Martyr#1's Avatar
Rotary engine.....NO PISTONS.
ROTARTY ENGINE INFORMATION=CLICK RIGHT HERE
First off,I can understand being a newb.....but research things before you buy or work on them in haste as it will save you headaches in life.
Next,
Do you have a RHD RX7 that was imported to the USA or are you overseas? The reason I ask is there is not a USDM RX7 after the 1995 model year. Just curious?
Now to find a fix for your problem,you are on the right track by asking questions,but you are gonna be like the old saying
"There are many ways to part a fool and his money" and you are gonna probably find out how much money after this because you didn't get good information before making a decision on the car to service the car.
So if I come across as a jerk.....I am not worried.....as you put it I am being frank/blunt/brutally honest.
EDIT: I just read the FAIL THREAD fully....You should not try to work on this car...take it to someone that knows rotaries if not you might be putting in a new engine for your customer.
Old Jan 12, 2010 | 09:54 AM
Android Army
Old Jan 13, 2010 | 02:32 AM
PENTECH's Avatar
thanks .... where in asia yes most of the rx here are converted. we already tried to convert from RHD to LHD. everything are fine. except my new clients. just learned from them some mechanic already opened their engines after a two weeks the engine get slowed, rough idle, and we DYNO tested it gooosh the HP is around 180 only. so ibelieved there realyy something wrong in engine
tbiggybig
35
Jul 14, 2022 06:14 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Road Cone
Nov 6, 2015 01:52 PM
Ivan2terrible
Oct 24, 2015 05:21 PM
Fickert
Sep 9, 2015 01:21 PM
