Can CEL P0113 Cause Engine to DIE?
Old Dec 30, 2009 | 05:41 AM
AJ's Shinka's Avatar
Enthusiast
Unhappy Can CEL P0113 Cause Engine to DIE?
So my 8 has been stalling out randomly since I got her two months ago. I thought it was the MS ignition wiring that was backwards, which it was. But now it still backfires and stalls out and I can't get it to restart until the next day, probably flooded.
Now I am getting this P0113 (Intake Air Temperature Circuit High Input) code and want to know if the two are related. I swapped out a known good MAF, no fix. I will troubleshoot wiring (MAF to PCM) but I want to get rid of the stalling issue first. I would like to separate the two issues if one doesn't have to do with the other.
She starts up just fine and idles great and drives smoothly, but all of a sudden out of nowhere she backfires and stalls out.
Old Dec 30, 2009 | 06:32 AM
invasion08's Avatar
This website has some very good info
http://www.myrotarycar.com/portal/fo...3le/index.html
Old Dec 30, 2009 | 05:58 PM
Enthusiast
Sweet I have seen this before from Mazsurfer but only briefly looked at it.
Under 11. Engine stalls the MAF is mentioned.
Thanks.
Old Dec 31, 2009 | 12:23 AM
@!!narotordo's Avatar
FLAME ON!
AJ we can swap intakes if you want? maybe the stock intake box is jacked up
Old Dec 31, 2009 | 04:12 AM
Enthusiast
I am game to try anything right about now.
Edit: Backfire caused this errant code. It was my ignition setup due to hasty install and overlooked wires all a long. Cased closed.
Old Aug 25, 2016 | 11:14 AM
Jzmoreno89's Avatar
Having the same issues
I just replaced the ignition coils and spark plugs n now I'm getting a code on my car p0113 has anyone had this issue!? Need help from anyone.
vapor2
Nov 3, 2020 03:38 PM
Skyl3r
Dec 2, 2019 04:51 PM
Rx808BI
Aug 9, 2015 10:06 AM
Rx8Lovin
Jul 25, 2015 08:39 PM
dbarber
Jul 25, 2015 01:34 PM
