CEL plus won't go past 3k RPM
Old Dec 26, 2009 | 09:49 PM
catalan's Avatar
I own a 04 mt rx8 w/ 49.9k miles on it. Drove it this afternoon about 15 miles and the car ran just fine. Car sat about 5 hrs and when I started it, the CEL went on and it wouldn't go past 3k rpm. Drove it all the way home unable to go past 35mph w/ an average of 20-25mph most of the trip.
Old Dec 26, 2009 | 10:22 PM
rx8montreal's Avatar
check your cat.... may be dead
Old Dec 26, 2009 | 10:33 PM
catalan's Avatar
sorry im not really car savvy what exactly would distinguish if it's dead or not?
Old Dec 26, 2009 | 10:38 PM
kingaaron's Avatar
Are you going to check the CEL?
Old Dec 26, 2009 | 10:40 PM
catalan's Avatar
yeah i planned on taking it to autozone tomorrow to get the code checked
Old Dec 26, 2009 | 11:42 PM
Limp Mode...there are a few things it could be...
MOP, Drive by Wire system..throttle or Acc pedal
See what the CEL is and get back here
Old Dec 27, 2009 | 12:02 AM
catalan's Avatar
Will do thanks for the advice. One question what does MOP mean?
Old Dec 27, 2009 | 01:51 AM
catalan's Avatar
Well, after letting the car sit again for a bit it drove just fine and the CEL went off on its own. If the CEL goes on again ill take it to autozone asap as long as theyre still open near my house.
Old Dec 27, 2009 | 01:57 AM
josuar88's Avatar
The Crawlster
Maybe ssv valve?
Old Dec 27, 2009 | 01:11 PM
catalan's Avatar
Alright so the CEL went on again this morning and i took it to autozone and then it wouldnt start up. Checked the battery ended up being bad and still wouldnt start even after jumping it. The codes read on the CEL were 2258x2, 2260x2 and 2102. They told me these are mazda factory codes and were unable to pull it up on the system.
Old Dec 27, 2009 | 01:13 PM
dozer's Avatar
on his 3rd rx8
^google is your friend, so is the ^search function up top....ill help you out, im drunk and im happy
Old Dec 27, 2009 | 01:15 PM
dozer's Avatar
on his 3rd rx8
https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
heres a sticky that came from the tech garage all codes are listed on the first post, now figure out what you have
Old Dec 27, 2009 | 01:17 PM
dozer's Avatar
on his 3rd rx8
P2258 AIR pump relay control circuit high ON 2 CCM
P2260 AIR solenoid valve control circuit high ON 2 CCM
^i guess dannobre guess it right
Old Dec 27, 2009 | 01:28 PM
catalan's Avatar
searched through some threads and it said that the codes could be caused by a flat battery. So hopefully the charge he puts on my battery fixes this will post back after i go back to get my car. thanks dozer for the help
Old Dec 28, 2009 | 12:31 PM
catalan's Avatar
car is up and running again after getting the battery recharged and terminals cleaned out a bit. only about 50 miles so far since then so not too sure if the CEL will go off again. Will post back if it does. Thanks again for the help.
RevMeHarder
Jun 1, 2026 02:30 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
Forevermore
Sep 20, 2015 01:04 PM
DVerdeyen
Sep 13, 2015 11:19 AM
