rotor swapping
Old Dec 22, 2009 | 07:01 PM
sen2two's Avatar
rotor swapping
A friend of mine wants to put lower compression (from Rx7) rotors into his renesis motor. But im not exactly sure if the side seal placement will be a problem. Or anything else.
I know everything that needs to be done to put renesis rotors into the older 13b's. But i never looked into putting older rotors to the newer motor. And i dont have any spare parts to check for myself at the moment...
Old Dec 22, 2009 | 07:14 PM
Brettus's Avatar
Boosted Kiwi
been tried - unsuccessfully .....
Old Dec 22, 2009 | 07:20 PM
zoom44's Avatar
you can put renesis rotors in the older 13b but not the other way around
Old Dec 22, 2009 | 08:24 PM
sen2two's Avatar
can you explain why?
side seal placement???
Old Dec 22, 2009 | 08:38 PM
Try it, and watch your rotor housing turn into trash in matter of seconds !
Old Dec 22, 2009 | 08:45 PM
sen2two's Avatar
ok...again. why?
Old Dec 22, 2009 | 09:16 PM
sen2two's Avatar
is it only a problem with the housings, or is there a problems with the ports? not having the compression ring???
Old Dec 22, 2009 | 09:37 PM
expo1's Avatar
He's as bad as Can
https://www.rx8club.com/rx-8-discussion-3/rx-8-rotor-rx-7-rotor-89607/
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/rx-7-5th-gen-rotors-118830/
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/cracked-front-housing-119714/
Old Dec 22, 2009 | 09:58 PM
sen2two's Avatar
^ thanks for the info
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
bosstin87
Oct 5, 2015 06:52 AM
Stubbs
Sep 27, 2015 04:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
Trekk
12
Sep 25, 2015 03:08 PM
