help me! oil light. on the road, 5 hours from home
Old Nov 29, 2009 | 01:06 PM
mlfarrell's Avatar
My oil light came on while driving home today. I'm 5 hours from home.
checked the level, she's full. After starting back up, 5 more miles and it happened again/
I'm using wireless internet at a closed toyota dealership right now. I have no clue what to do. Its sunday and everything is closed
I'm off route 40 in hagerstown, md
she's running fine
Old Nov 29, 2009 | 01:25 PM
Jon316G's Avatar
Grasshopper
Just to cover the basics, you did wipe the dipstick before checking the level... right?
Old Nov 29, 2009 | 01:30 PM
expo1's Avatar
He's as bad as Can
Is your vin number between 2004 RX8 - VINS: JM1FE17* *40000000 to 40111043 ?
Early 2004 had an issue with the oil pan that would show a false low oil reading.
mlfarrell's Avatar
Yes. She was about a 3/4 or 4/5 full. Filled it up completely. My buddy thinks its a minor electrical problem. The gauge is fine, just the light. I'm gonna drive home with the music off and listen to the engine the whole time. Hopefully I make it.
Old Nov 29, 2009 | 01:31 PM
Jon316G's Avatar
Grasshopper
Then as expo1 stated above, it may just be giving you a false reading.
I wouldn't worry about it.
Old Nov 29, 2009 | 01:32 PM
mlfarrell's Avatar
Originally Posted by expo1
is your vin number between 2004 rx8 - vins: Jm1fe17* *40000000 to 40111043 ?
jm1fe17n740128597
Old Nov 29, 2009 | 01:34 PM
Jon316G's Avatar
Grasshopper
You could still have a flaky oil level switch.
Brettus's Avatar
Boosted Kiwi
you will be fine - as long as you have checked the level manually and all is well there ...
Old Nov 29, 2009 | 01:35 PM
Old Rotor's Avatar
See if your car is in this vin range on this "TSB". If it is you might be OK. When you start your car dose the oil gage needle move to the right of the center like normal?
http://www.finishlineperformance.com...13-04-1341.pdf
Old Nov 29, 2009 | 01:36 PM
@!!narotordo's Avatar
FLAME ON!
Less is more and at wot 9+k rpms your oil light will come on
Old Nov 29, 2009 | 01:45 PM
StealthTL's Avatar
Metatron
When mine had this problem (it was the sensor) it only happened above 75mph on straight highway.
Dealer replaced pan and sensor.
Old Nov 29, 2009 | 02:17 PM
05rx8mazda's Avatar
B.I.G
mine did the same thing.. but oddly it started to do it after it over heated on me and my motor was on its way. =[
Old Nov 29, 2009 | 08:16 PM
mlfarrell's Avatar
Just got home. She ran great. No oil light or anything. I'll get the tsb's checked on my next oil change.
Purred like a kitten, even when redlining 3rd gear (I got a 4 speed)
Old Nov 30, 2009 | 01:58 PM
4 speed auto..........
Jesus Martinez
44
May 6, 2025 08:09 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
atmd
Aug 19, 2015 12:43 PM
