How to remove E-Shaft Bolt!
Old Nov 7, 2009 | 01:33 PM
benh's Avatar
Can anyone help me find the way to remove the e-shaft bolt. I have oil leak and trying to replace the front main seal myself. I am stuck at the E-shaft bolt couldn't get it off. I have heated it up with the blow torch, make sure to secure the clutch with the 2x4. Just don't know how to get the bolt off without the e-shaft for turning. Anyone have done this before please help me out the some tips. Thanks
Old Nov 7, 2009 | 01:37 PM
There are some major pitfalls if you have never done this before so be careful...
Big *** impact gun is the best answer..............
Old Nov 7, 2009 | 02:42 PM
benh's Avatar
Pitfall??? I follow madzatrix tip on anchor down the clutch. As far as big *** impact gun, the engine is in the car so i don't have enought room for the big gun.
Old Nov 7, 2009 | 05:33 PM
Jon316G's Avatar
Grasshopper
When you say that you secured the clutch with a 2x4, are you saying that you removed the transmission and wedged a 2x4 onto the flywheel to keep it from turning?
If so, that is all you should need to do to prevent the e-shaft from turning.
Old Nov 7, 2009 | 07:51 PM
benh's Avatar
No. the 2x4 is to wedge the clutch padle so all the stuff behind the pulley hub will stay in place and not fall off of it position. If this step is not perform, things can go wrong and that I may have to take the front cover off.
Old Nov 7, 2009 | 07:57 PM
Brettus's Avatar
Boosted Kiwi
i have done this with the engine in the car . I jammed a crowbar into the holes in my act flywheel - not sure if you can do similar to std flywheel but if you got someone to jam the ring gear teeth with something it may work . There is actually a special tool for this but I have a feeling the gearbox needs to be removed to use it .
Then get a 1/2" drive socket and bar on the nut . Attach a long length of pipe to the bar and swing like f**k on it
Old Nov 7, 2009 | 08:14 PM
Jon316G's Avatar
Grasshopper
That is pretty much what I was thinking about Brettus.
I use a flywheel stopper to prevent the e-shaft from spinning when removing the flywheel nut.
Don't see why you couldn't do the same thing for the e-shaft nut.
Sucks to remove the transmission just to do this, but its a sure way to prevent the e-shaft from spinning.
You can buy the flywheel stopper here (bottom of page):
http://www.mazdatrix.com/8clutch.htm
Old Nov 8, 2009 | 12:11 AM
UrbanOcho's Avatar
Stick Specialist
Originally Posted by benh
I am stuck at the E-shaft bolt couldn't get it off. Anyone have done this before please help me out the some tips. Thanks
try kissing it some more at the top of the shaft
usually works for me
Old Nov 8, 2009 | 03:34 AM
ayrton012's Avatar
Ayrton Senna Forever
Maybe heating will kill the thermo oil pellet in the e-shaft, and if it stuck in bypass mode you will have oil pressure problems. The problem is that you won't see it without gauge, but your engine will die.
I think it is better to throw away the pellet, and plug in the e-shaft's oil bypass holes.
Old Nov 8, 2009 | 04:21 AM
StealthTL's Avatar
Metatron
Put a stout strap-wrench on the front crank pulley.
S
Old Nov 8, 2009 | 04:43 AM
mazdaverx7's Avatar
RX-Heaven
why not take the time and poull the engine and set it on the flywheel and do the front cover seal as well? mazdatrix sells a flywheel stopper that will hold the flywheel in place if need be. a 3/4 drive impact gun is your best bet to removing that bolt.
Old Nov 8, 2009 | 08:37 AM
Just get a good solid breaker bar and use a chain wrench to hold the pulley.
Old May 21, 2013 | 03:36 PM
Flywheel stop FTW.
Old May 21, 2013 | 03:38 PM
They both come off easily with a 1/2 or 3/4" impact
Or a long breaker bar and extension
Old May 21, 2013 | 03:39 PM
Or, the leg of an engine hoist on a breaker bar
Old May 21, 2013 | 03:42 PM
LOL...or a handle from a jack
Old May 21, 2013 | 03:43 PM
Brettus's Avatar
Boosted Kiwi
Sledge hammers are surprisingly versatile tools ....that's all i'm sayin'.
Old May 21, 2013 | 03:44 PM
Yeah, my jack handle doubles as a breaker bar extension quite often. We actually tweaked the flywheel stop trying to remove a flywheel nut recently. Pretty scary with the engine on the stand.
The 5lb sledge is a very versatile tool,
Old May 21, 2013 | 03:45 PM
That's why the 3/4" impact is the king The one I have will remove the flywheel bolt with one swat
Gotta watch it doesn't make the motor flip over though
Old May 21, 2013 | 03:48 PM
Rotaman's Avatar
NZ
You guys are all trying to do this the hard way.
Get your socket and bar and place the socket on the bolt and rest the bar on a chassis rail or something solid so it can't move.
Then put your ignition key in the ignition and turn the key so the starter motor is just starting to turn the motor and then turn the key off.
Job done.
I've used this method when doing cranks seal on Subaru's, works every time.
Simply and easy.
Your impact driver is the starter motor, it has more torque than any impact driver.
Rotaman
Old May 21, 2013 | 03:50 PM
Yeah, my compressor just died and I am searching for a big replacement now so I can run proper shop tools like a blast cabinet. etc. I bought my father a 900FT/lb 1/2" IR impact and that thing is awesome. I see now they have 1200ft/lb 1/2" impacts
It's all about the tools man!
Old May 21, 2013 | 03:59 PM
Brettus's Avatar
Boosted Kiwi
Job done.
Simply and easy.
Rotaman
Tried this on my 8 years ago .... didn't work for me .
Old May 21, 2013 | 04:10 PM
Rotaman's Avatar
NZ
Brett
Maybe your starter motor was a bit tired. I'm sure you aren't going to tell me you have more torque in your arms then a starter motor.
Anyway this is a very simple and effective way to do it, if your starter motor is not stuffed as well.
Rotaman
Old May 21, 2013 | 04:27 PM
Brettus's Avatar
Boosted Kiwi
When swinging on the end of a 1m+ long bar .............yes ............... a lot more
Old May 21, 2013 | 04:43 PM
Brettus's Avatar
Boosted Kiwi
Only just got this - 4 years too late .
