Read-out from Mazda Dealer
Old Oct 17, 2009 | 08:14 AM
fish1's Avatar
Just received this printout from Mazda dealer.
Looks like alot of gobbly-gook to me except for the bottom part.
The read-out recorded my last driving session and shows some misfiring.
Looks like it may be my cat?
I've had the vacum testing done, de-carb procedure and all plugs/coils and wires replaced with the BHR ignition set.
Still having some hesitation and bogging at the high rpm's with no cel's.
Hesitation only happens after I have been driving for awhile (close to or more than an hour)
Old Oct 17, 2009 | 08:30 AM
Engine is bad.
Old Oct 17, 2009 | 08:36 AM
fish1's Avatar
Oh, forgot to mention; had the compression check done and results came back as normal readings to higher than normal compression.
Engine has 99,000 klm on her.
Old Oct 17, 2009 | 12:28 PM
RedRocket8's Avatar
PISTONS are for (|)
if the compression test came back normal, and you changed the plugs and coils. I would say that the CAT's efficiency is probably below the threshold, or maybe try looking at the o2sensors, and visually inspect the cat core and see if its broken or damaged at all. other than that i have no idea. good luck
Old Oct 17, 2009 | 02:35 PM
Those are very small #'s of misfires.....likely negligible
I would check your fuel pump.....
Bad gas?
Old Oct 17, 2009 | 03:03 PM
iwannagofast's Avatar
Open up your glove box and see if there's a can of liquid schwartz in there.
Old Oct 18, 2009 | 07:09 AM
fish1's Avatar
alas the schwartz is not with me
Could the cat be clogged and not giving off any cel's?
Old Oct 18, 2009 | 10:16 AM
shazy's Avatar
Cat could be clogged. Take the midpipe off and physically look through it.
Old Oct 19, 2009 | 10:40 PM
fish1's Avatar
The response I received from Mazda Canada today was the cat is fine.
The only other thing to check now would be the SSV?
However I am not receiving any cel's (specifically a 2070 code).
Is it possible to have a sticky SSV and not receive any cel?
Old Oct 20, 2009 | 08:40 PM
Cam's Avatar
Cam
this space for rent
From the printout, the cat is fine, as well as the 02 sensors. 4 misfires over 10 drive cycles is nothing.
I would check your fuel pump as well.
gwailo
May 14, 2024 06:57 AM
TJSiegrist
Sep 10, 2015 09:29 AM
chris424
Sep 2, 2015 10:18 AM
Red line envy
Aug 22, 2015 08:49 AM
digitalmonkey79
Jul 29, 2015 12:09 AM
