Wheeldog
10-09-2009, 11:51 AM
Hi, First off I want to say that I've searched and searched on here and found some very good information about storing my car for winter but I just want to make sure I get all the facts strait and for when I put my 8 away for the snow. I'm going to try and make a checklist of sorts and see if it makes sense.
PS: Oh yeah, this is in a small detached, windowless, non-heated garage with not a whole lot of room on either side of the car(just enough to get in and out of one side and enough for a child to maybe get out on the other.
1) Wash and wax it well. With this I also plan on washing and waxing each wheel by removing it and cleanign the outside and inside(don't know if the wheel part is needed).
2) Change the oil and filter, mine is about due so I think this would be a good thing to do.
Here is where I get some conflicting responses.
3) Do I leave the battery in of take it out? I was planning on firing it up and letting it run for 15-20 every week/other week and if I take the battery out I'll have to put it back in. What are the opinions on this. If the ground is clear enough or not-salted I plan on taking it around the block/parking lot to spin the tires up.
4) Fill the tank and put in some Stabil. I've used this stuff on 2 cycles with success and thought it might be a good idea for my car now.
5) Place some steel wool in the tail pipes to keep critters out(of course remove this when/if I start it up/drive it around.
6) Get a good clean car cover and put it on it. How necessary is this part? I know everyone talks about it and is all aboud putting one on, but I just wondered if putting one on if I'm still going to fire the car up will be a good idea and if it will do much beyond keep the dust off the car. I thought putting it on and taking it off might cause more issue then it prevents, and I can wash and clay bar the dust off when I take it out in the spring. If this is a dire need then what would someone suggest since I've heard the OEM one is really tight.
Any other suggestions? I know people use jackstands but that makes it hard to move it after and it may not even be possible for me with the layout and size of the garage. Sorry 'reposting' this stuff but I did search and just want to make sure my findings seem right.
