Does resetting the OBDII system reset to fuel trim?
Old Sep 29, 2009 | 12:02 PM
tmak26b's Avatar
Just curious, thanks
Old Sep 29, 2009 | 12:05 PM
if you're just talking about CEL. then nope. it wont
if you'r talking about pulling battery or pulling "Room" fuse, then yes.
Old Sep 29, 2009 | 12:26 PM
tmak26b's Avatar
The stupid fuse resets the radio and tripometer, kind of annoying. I was looking for another to con the computer dang
Old Sep 29, 2009 | 10:36 PM
alnielsen's Avatar
It will only reset the fuel trim temporarily. The ECU will relearn and you will be back where you started.
Old Oct 1, 2009 | 10:02 AM
SEANMAC777's Avatar
Is this why the car will die everytime I come to a stop sign or am coasting for the first 30 minute after I put the battery back in the car? Or is that another problem?
Old Oct 1, 2009 | 10:26 AM
Yes, you are correct.
Usually you can drive around the block two or three times. Shut it off each time and by the third time the ECU should be re-programed to idle.
Old Oct 1, 2009 | 12:20 PM
That means either your Throttle body has a problem and/or your Engine has a problem.
IT has NOTHING to do with ECU resetting, shutting down at stop sign is NOT the way its supposed to be.
I've been there. End up BOTH had a problem, Replaced under warranty
Old Oct 1, 2009 | 02:14 PM
SEANMAC777's Avatar
nice........
check my other thread "running terrible....need help"
Do you think this along w/ the other problems means I'm getting a new engine?
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
iwannarun
Sep 6, 2015 01:37 PM
