It's amazing
Old Sep 25, 2009 | 06:50 PM
jsjjr's Avatar
His 8
It's amazing
how much a difference cleaning your maf and K&N airfilter will make the car feel. Unfortunately, I'm still getting this erratic putt putt putt putt at idle. I thought the maf and air filter being dirty might be the cause of it.. Anyway, the car sure 'feels' different in the butt-o-meter.
Old May 18, 2010 | 11:54 PM
living the dream's Avatar
how did you clean the MAF sensor?
Old May 18, 2010 | 11:56 PM
HomicidalApple's Avatar
should have used the MAF cleaner from pep boys or wherever you prefer
laythor's Avatar
I zoom therefore I am.
there's a diy for it, but you basically buy a can of MAF cleaner at the auto parts store. Remove the MAF, spray, careful not to touch any of the little bits... dry and done.
then you need to reset the ECU and drive around for a bit
Old May 19, 2010 | 08:57 AM
adamwzl's Avatar
<3's Bunnies
reseting the ecu is that 20 brake stomp procedure correct?
Old May 19, 2010 | 09:16 AM
RIWWP's Avatar
20-brake pedal stomp only resets some of the parts of the ecu, but it does reset the e-shaft sensor and fuel trims, which are what matters here.
Old May 19, 2010 | 09:26 AM
adamwzl's Avatar
<3's Bunnies
Yep one step i forgot to do when I cleaned my MAF. Then I went to the NJ meet, so I got about a good 300 or more miles driven after doing the MAF cleaning.
Wonder if I need to still reset the ECU
Old May 19, 2010 | 09:32 AM
RIWWP's Avatar
Over time, it will 'reset' itself, as it adjusts. Resetting just speeds up the process.
I've actually been resetting it every 3 days recently, as about 7 days from last reset I start feeling very noticeable power loss down low. Haven't found a reason for it, but resetting the fuel trims seems to restore lost power for about a week.
Ignition is all new, cat is new, MAF is clean, etc...
Vlaze's Avatar
The Angry Wheelchair
http://www.rx8blog.com/how-to-reset-ecu-on-mazda-rx8/
20-stomp brake pedal method only resets e-shaft. To reset fuel trim you have to disconnect the battery for 10+ minutes.
Old May 19, 2010 | 09:34 AM
RIWWP's Avatar
Everything I have seen and felt says that the fuel trims are reset with the 20-brake pedal stomp. I'll see if I can find the manual PDF on here somewhere. There is another procedure that clears the other half of the ECU, disconnecting the battery does both.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
chadsta
Sep 20, 2015 11:00 PM
Tros
Sep 16, 2015 08:53 PM
WranglerFan
Sep 15, 2015 12:09 PM
