Transmission Rebuild Literature
Old Sep 7, 2009 | 09:16 AM
Titaniumtt's Avatar
More Turbo's than you
Is there any online source that has the FSM for the RX8 6-spd? Just about every single RX7 piece of lit that came from the factory can be found online, wondering if someone took the time to put some lit that pertains to the RX8's tranny online. I've searched and searched (here and elsewhere) and can't find anything.
Thanks guys.
Old Sep 7, 2009 | 11:38 AM
ken-x8's Avatar
RX-8 FSM:
http://www.hi-impact.org/ryang/modif...8_manuals.html
FSM Himself:
http://www.venganza.org/
May you be touched...
Ken
Old Sep 7, 2009 | 05:06 PM
next time, any questions, search is ur friend.
seriously, SEARCH
thx
Old Sep 7, 2009 | 07:38 PM
Titaniumtt's Avatar
seriously, SEARCH
thx
Thanks, yeah I did, didn't find anything. Appreciate the help though, that's great.
Originally Posted by ken-x8
FSM Himself:
Ken
Thanks Ken, what I'm really looking for is the lit that breaks down the complete tranny dissasmbly/rebuild. The FSM is awesome, but it doesn't go into any detail other than remove/install. Is there a seperate transmission book for this particular Aisin box?
Thanks Guys
-B
Old Sep 9, 2009 | 01:53 PM
The factory FSM does not cover the engine or transmission or electrical in detail.
These are all covered in their own FSMs for each one
The dealer can get them, but they're usually FS on Ebay at a cheaper price
Old Sep 3, 2013 | 07:39 PM
anthonyallred's Avatar
Dont suppose anyone has this detailed transmission teardown info / FSM in PDF format?
Really looking for the Transmission Bell Housing Bolt Torque specs. Seems my transmission is is leaking from one of the bellhousing seams.
Old Sep 4, 2013 | 10:43 AM
j9fd3s's Avatar
Foxed.ca - Mazda RX-7 Manuals
Old Sep 4, 2013 | 11:00 AM
Carbon8's Avatar
Yank My Wankel
You have bigger issues than that, their should be no fluid inside the bellhousing. The bellhousing has a hole at the bottom of it to drain fluids that may leak inside.
If you have fluid in your bellhousing its probably oil from a rear main seal failing.
Old Sep 4, 2013 | 03:11 PM
NO_PSTNS's Avatar
^^ Bingo.
Old Sep 5, 2013 | 12:59 PM
Karack's Avatar
Rotary Evolution
or it could be residual from sloppy oil changes.
the factory position for the oil filter has much to be desired.
Shankapotamus3
Mar 14, 2021 03:53 PM
airlive
Jun 28, 2020 07:46 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Von Walker
Sep 13, 2015 03:54 PM
