View Full Version : Ignition Coils/Spark Plugs/Wires
Jasonvaldez
09-02-2009, 12:01 AM
After doing research for a day or two on the forums i have realized my car has 70k miles and the coils, plugs, or wires pry have NEVER been changed i want to go after market no questions asked. but my question is what are some good brands for ignition coils, plugs, and wires i was thinking MSD but I don't know if they make those for rx8s. i also have a few other questions so RX8s have FOUR ignition coils???!!! i am still in a learning proccess of this car. and where is it located?
Thanks. any tips would be very helpful thanks again.
dozer
09-02-2009, 12:04 AM
yes the 8 has 4 ignition coils, 4 wires and 4 spark plugs...if you really wanna go aftermarket, go with the BHR kit (Pm one of the guys over at BHR and theyll give you the treatment) im pretty sure their kit comes with aftermarket wires too, as far as spark plugs, nothing beats OEM and im pretty sure that you can order new plugs with your BHR kit
volcomx31
09-02-2009, 12:09 AM
do what dozer said..and change your air filter with a k&n one
RX8pwnage
09-02-2009, 12:19 AM
BHR ignition hands down. Accept no substitute.
alz0rz
09-02-2009, 12:37 AM
If you don't want to do an ignition coversion (BHR) then stock is sufficient if your car is N/A.
Stock Coils, Plugs, and wires are a little less then $300.
Jasonvaldez
09-02-2009, 02:13 AM
I have an aem cold air and who would I pm?
Charles R. Hill
09-02-2009, 02:14 AM
Me......
Easy_E1
09-02-2009, 02:52 AM
Yeah, PM that guy^
shazy
/\ Him.
Charles R. Hill
09-02-2009, 03:55 AM
Just to clarify; the only direct bolt-in performance coils for the RX-8 are the Okada Products coils and they are $700 (or so) per set. Any other coil swap kit will either require a conversion wiring harness or a molestation of your factory wiring.
bse50
09-02-2009, 04:14 AM
I would call your upgrade a "direct swap" as well. Your wiring harness is perfect and requires no cutting whatsoever. The only difference maybe is that you don't change your coils one by one but place the whole coil pack in at once!
Now prove me wrong as you always do :(
Charles R. Hill
09-02-2009, 04:20 AM
Some people only want to swap coils and wires without having to do a full harness conversion and bracket installation. JasonValdez is a new member who is not quite familiar with the choices available for addressing the RX-8's ignition system.
I just sent him a PM that summarizes the past few years around here and BHR's approach to problem-solving and product-development. The only thing I forgot to mention is that we are notoriously slow at getting our stuff to market but that I am pretty sure it is worth the wait. On the other hand, with each new product release the development time seems to get shorter and shorter.
bse50
09-02-2009, 04:24 AM
Agreed on the times getting shorter lately. You guys really improved at that!
Well, 485$ (BHR) vs 700$ for the okada (with unknown specs) i'd pick your kit up anytime, especially since you provide a real warranty and did some extensive tests on the coils.
I actually found easier to swap the whole coil pack than the coils one by one anyway. Maybe because i am goofy when working on the car :)
Charles R. Hill
09-02-2009, 04:29 AM
I was surprised when you chose to get our kit rather than the infamous "Italian Tune-Up". :lol2:
bse50
09-02-2009, 04:33 AM
I did some italian tune-up with other parts. I did polish my throttle body with a dremel tool ;)
That's also how i do the simple "smoothening" ports to the engines! Martina thinks that i'm in love with that tool :lol:
