View Full Version : MY OMP never worked
turborx8
08-19-2009, 10:09 AM
I am really happy I installed a Sohn OMP adapter when I first bought my car because the OMP never worked. I have the adapter connected to a small 2stroke reservoir and it only burned a few ounces of oil in the past 30,000miles. I knew right away that I needed to premix.
Couldn’t I just cap off the nipple on the OMP adapter and just premix? :dunno:
I would rather use the 2stoke reservoir for my windshield washer fluid.
09Factor
08-19-2009, 10:54 AM
I don't see why not. I had to remove the OMP for my turbo project and plan to pre-mix.
I also know several rx7 owners that pre-mix exclusively.
OnRails
08-19-2009, 11:12 AM
I know that's what some of the race teams do. Seems kind of inconvient for daily use but if you're doing it every time anyway why not.
One of the benefits I'm told is a much cleaner engine internally.
MazdaManiac
08-19-2009, 11:50 AM
Why not crank it up with the AP?
Best of both worlds.
rotary.enthusiast
08-19-2009, 12:09 PM
I was planning on getting the OMP adapter myself, but ended up deciding to try pre-mix only. I zero'd out all the OMP tables with the AP and have been premixing ~1 oz. per gallon for the last 4 months with no (noticeable) ill effects so far. I keep two small bottles of two stroke in the trunk, and just dump the entire contents of one in at a fill up.
I'm not 100% certain that the OMP isn't still putting out a little bit of engine oil, but my oil level hasn't changed noticeably between oil changes. I also started the heavier pre-mix one full gas tank before turning off the OMP.
Still not sure if it's a great idea or not. I guess I won't know until my engine dies and I have to tear it apart. :dunno:
turborx8
08-19-2009, 12:46 PM
The map you gave me does have the omp cranked. It simply does not work.
chickenwafer
08-19-2009, 01:50 PM
How do you have your OMP air bleed hooked up?
csl
08-19-2009, 08:18 PM
shaft stuck or line clogged? I took mine out for cleaning and after that drink like a fish :)
Brettus
08-19-2009, 08:40 PM
yes
turborx8
08-19-2009, 09:38 PM
Good question.
I dont even know what that looks like. :dunno:
I8U
08-19-2009, 10:07 PM
turbo, you said your OMP never worked? How much 2 stroke have you been running to counteract the faulty OMP? With a non-functioning OMP you should be running atleast an ounce per gallon of fuel, just to be on the safe side. If you haven't been I bet your engine is f'd after running like that for 30k.
turborx8
08-20-2009, 12:26 AM
I premix 8oz per fill up.
04RX8man
08-20-2009, 05:20 PM
^I'd up it more....I'm using 8oz with my OMP still pumping away..since yours is not working like you said....I'd listen to I8U and use At LEAST 1 oz per gal
ChrisRX8PR
08-20-2009, 05:27 PM
You can premix in the fuel, its been done for years in RX-7's....
You do have to be careful not to overdo it because depending on what you are using it has the capacity to clock your fuel filter.
It works wonders for people with no OMP.
Chris
MazdaManiac
08-20-2009, 05:42 PM
Just remember that the oil effectively lowers the octane of your fuel.
chickenwafer
08-20-2009, 05:47 PM
Good question.
It's one of the two larger hoses hooked into the accordion on the factory airbox. The other is the Jet Air hose and should be plumbed to boost (or have a check valve if hooked up to vacuum) and the OMP air bleed should be hooked up pre-compressor.
turborx8
08-20-2009, 06:50 PM
Hmmm... I have two Mazsport check vlaves on those two hoses. Could that be the issue? lol
http://www.turborx8.ca/pictures/engine.jpg
turborx8
08-20-2009, 06:52 PM
Good to know.
I use 94 octane anyways just to be safe.
chickenwafer
08-20-2009, 06:55 PM
Yes, remove the check valve off the OMP air bleed
turborx8
08-20-2009, 07:38 PM
I will give that a try. Thanks man!
Red Devil
08-23-2009, 07:23 PM
I've actually been considering the direct opposite and dialing down via the AP and increasing the amount of premix. With the two injector locations on the majority of our engines I'm not sold that cranking it up is superior to premixing. At this point I suppose like many other things this argument is academic and what floats your boat. But my rationale is that I have little interest in doing a sohn adapter and would rather have 2 stroke enter the combustion chamber rather and oil from the pan.
turborx8
08-23-2009, 09:46 PM
Keep in mind, you can start using synthetic oil when using the sohn omp adapter.
Vlaze
08-23-2009, 11:19 PM
The Sohn Adapter does just that and doesn't take oil from the pan, but takes it fresh from a reservoir.
My question is has anyone taken an OMP off the 8 and cleaned it down when they did an oil change? If so how much of a PITA was it to bleed the system when you disconnected the lines? How did you clean it? And from what I've read the typical rate is 1 qt every 3k miles should be consumed or is that with the AP flash only. Since getting the car from the dealer used a few months ago I presume it should already have the latest flash that bumped the oil consumption rate up... but assumptions are a dangerous thing.
I8U
08-23-2009, 11:20 PM
You could always use synthetic oil...sohn adapter or not.
Vlaze
08-23-2009, 11:22 PM
Yes, but based on the history of the seals and burning with synthetic oil, it's not a good thing to do this. Which is exactly why it's another benefit using the adapter so you can run synthetic in the engine without getting it in the combustion chamber.
turborx8
08-23-2009, 11:23 PM
You could but shouldin't!!!
Think about it. Synthetic oil does not burn very well.
I8U
08-23-2009, 11:25 PM
WOW, not into a synthetic oil is bad for rotaries conversation...ghey. Been done, nothing proven. BTW, most decent 2 stroke is synthetic anyways so running a sohn adapter with 2 stroke defies your logic.
Brettus
08-23-2009, 11:30 PM
what effect did removing the check valve have ?
turborx8
08-23-2009, 11:36 PM
I haven't done it yet.
My car is in the shop getting the turbo replaced.
plain ole wanker
08-23-2009, 11:40 PM
What about Idemitsu Rotary Premix, AMSOIL Saber Professional both synthetics?:scratchhe
turborx8
08-23-2009, 11:43 PM
Yeah... engine oil and 2stroke oil burns differently even if both are synthetic.
Red Devil
08-24-2009, 09:21 AM
I understand both statements regarding the sohn adapter. It does not resolve the issue of delivering lubrication to the center of the apex seal. Premix from the splatter effect has a shot at it and has proven itself viable for decades. Numerous rotary race teams remove the mop completely and use straight premix on the Renesis.
I don't see the point in removing and cleaning the unit unless you have reason to believe it doesn't work. 1 quart every 3 K sounds about right and if you purchased from a dealer they should have you on the latest flash. If you really want to know call MNAO and be ready with your VIN number and they should be able to tell you.
TheWulf
08-26-2009, 09:39 AM
Just to get back to your original question...
I would disconnect the OMP completely if you do this (power connectors) otherwise you might build up a vacuum if your cap is too tight or suck in air if it isn't (not sure how big a deal that is).
Personally I'm more a fan of premixing than OMP since the OMP simply drips oil onto a single line inside the housing. I'm trying to find the picture that shows a single polished line inside a scorched housing, really shows how inadequate the OMP is in the first place.
And make sure you come out to M&M at some point so we can drool over your turbo setup when it's done. :)
