View Full Version : power steering problem PLEASE HELP!!
x MazDA 08-13-2009, 05:33 PM hey guys starting this morning my 8 has no power steering. i don't exactly know why but i have no idea where to start looking. is there a power steering belt, fuse, or anything else mazda could have thought up? please help me guys the mazda dealership is booked for to long..
thnx
Cory:shocking:
dozer 08-13-2009, 05:38 PM relax, relax, its ok DOZERs here, first off, your power steering is electric, thus no belts or no fluid...
alright now, right under your airbox and the tray that holds it, are 2 connectors, the bigger one on the right is for your power steering, pull it apart and clean the inside off both sides with keyboard duster (electronic cleaner) and dab a bit of dielectric grease on the 2 prongs, connect, start up and it should be gone....if the problem continues, it could be worse...
Jon316G 08-13-2009, 05:39 PM hey guys starting this morning my 8 has no power steering. i don't exactly know why but i have no idea where to start looking.
I can tell you where to start... the "search" option at the top since this has been covered many times here before.
All you need to know is in this thread:
http://www.rx8club.com/showthread.php?t=107481&highlight=power+steering
dozer 08-13-2009, 05:41 PM ^thats the second solution...
Jon316G 08-13-2009, 05:49 PM ^True... some have been lucky and cleaning the connectors once did the trick.
I wasn't so lucky (as I explained in that thread) and had to clean them at least once a week.
Which is why my wires are now spliced together.
x MazDA 08-13-2009, 06:22 PM dozer i love you i will be back on later to let u know if it worked thnx again
tear, tear, i was so scared...
Jedi54 08-15-2009, 12:41 AM did it fix the problem? (permanently?)
swoope 08-15-2009, 02:03 AM did it fix the problem? (permanently?)
nothing is fixed permanently.. ;)
but it does fix it. i just went through this at 114k miles.. it took no time at all.
do it yourself..
beers :beer:
Jedi54 08-15-2009, 10:28 AM had mine go out yesterday.
I'm leaning towards coolant getting on the connectors since the coolant light came on as I started my car (quickly went off)
30 minutes later...PS is gone.
going to pick up the updated harness and see if that fixes it.
Spinning Sushi 08-15-2009, 10:31 AM Pull out intake, pull out tray, pull apart the connector (It's the big one), clean it, add di-electric grease, reconnect the connector, start the car. If this solved it then proceed to put the tray back in, and put the intake back on. You might get a CEL for having the MAF disconnected after you start the car but that's nothing major for you since you have the Cobb AP to delete codes. :)
04RX8man 08-15-2009, 02:14 PM mazda needs to put a longer hose on the overflow tank....
Jedi54 08-15-2009, 02:47 PM ^^^ YES they do! :cussing:
Spinning Sushi 08-15-2009, 02:48 PM Why not just buy a new longer hose for $2.99 a feet at AutoZone like I did to prevent this from happening? Cheap simple fix.
Jedi54 08-15-2009, 02:51 PM that's already on my list of things to do when I fix the PS.
04RX8man 08-15-2009, 11:15 PM Already done RENESIS...but if MAZDA would fix it from the factory that's 2.99 I don't have to spend...damn that's like 1 beer....
x MazDA 08-18-2009, 04:36 PM papa dozer...i dont know which plug to clean. please help again
http://i299.photobucket.com/albums/mm313/xOMazdaRx8Ox/clampsfordozer.jpg
dozer 08-18-2009, 04:39 PM none of those, youre gonna have to completely take out the airbox(intake box) the the tray underneath it to get to the plugs
x MazDA 08-18-2009, 04:44 PM oh ok well thats a starting point then guess i know what i'll be doing later..thnx again i'll probably call for you again...:'(
dozer 08-18-2009, 04:46 PM no worries, just PM me if i dont post in this thread
MazdaManiac 08-18-2009, 04:56 PM papa dozer...i dont know which plug to clean. please help again
Nice to see you didn't even read the thread that you were referred to.
x MazDA 08-18-2009, 05:33 PM actually yes i did. im just very new to the car and still was a little lost and dozer was very nice about helping the extra bit. but yes i did read it and thank you for posting it
dozer 08-18-2009, 05:37 PM what i posted was just a quick fix, its worked fine for me, and im hoping it works for mazda, but if it doesnt then the next thing to do is whats in that thread
04RX8man 08-18-2009, 05:40 PM prob wouldn't hurt to clean the MAF either(the one on the left that you circled) but that has NOTHING to do with your P.S......
Jedi54 08-18-2009, 05:55 PM ^^^ and by cleaning the MAF sensor he means take it out, spray it with MAF cleaner (gently) and then let it dry.
don't get crazy scrubbing that thing.
