Fuel level sensors
Old Aug 3, 2009 | 11:24 PM
Fuel level sensors
Mine died....read empty all the time...so I pulled the fuel pump out to check out the sensors.
The sensors are variable resister units...and they can be removed without removing the fuel tank... The mounting bracket is a twist off bayonet mount...just turn it and it comes out easily
Took it out and found that I had separated the wire on one connector...crimped it back together and all was good
I was relieved...originally I thought that the bracket was fixed in the tank
Old Aug 3, 2009 | 11:26 PM
Good to know. Mine got stuck at half a tank a while back and they replaced my whole tank but didn't really give me an explanation.
Old Aug 4, 2009 | 12:03 AM
I'm not sure if you can actually BUY the sensors separately though
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
yankeepicker
Sep 11, 2015 05:42 PM
