zerobanger
01-05-2004, 10:57 AM
Just a question...
I will be ordering stage II at somepoint and was curious. You mention that stage II causes EGT to raise too high for the stock cat. If the stock cat/catback were used would we get the same 55 HP to the wheels?
The reason I ask, I use water injection on my 3rd gen Rx-7 and it it not only lowers intake temps, cools the engine and cleans the engine of deposits, but it also lowers EGT considerable.
While you dont usually put it on a n/a car, it works good with a high compression engine, especially if you change the timing, etc.
the other advantage is that it would allow you to run 87 octain even with stage II.
This is just a technical question I thought I would ask you about. I will likely go the route of changing out the exhaust, but I wanted your input. Someone may be interested in this idea.
thanks.
thanks.
