Tires Rubbing Going Wild
Old Jul 31, 2009 | 02:26 AM
G-Gray dude's Avatar
Boost Virgin Gonnabe
Hey i need help. i bought 18" x 8.5" Enkei RPF1 rims a while back and came with Godyear Eagle F1 all season 245x40 tires. the big problem is that everytime i go over the bump or pothole it will make a screeching noise. tires are rubbing the inside very bad. does anybody know what's my option at this point. as I seem to think that rolling fenders should fix the problem. my other question, are my tires too wide for my car?
Old Jul 31, 2009 | 02:49 AM
c41250n's Avatar
first, what offset are the wheels, 18X8.5 shouldn't be rubbing at all. and you wish 245 is too wide for the 8!
second, what are you lowered with?
front or rear rubbing? rub while going over bumps or turning?
we need way more info then just that!!
Old Jul 31, 2009 | 02:55 AM
Spinning Sushi's Avatar
I <3 Sushi
It shouldn't be screeching... that might be something else.
Old Jul 31, 2009 | 03:28 AM
pistonkilla's Avatar
im running 265/35's with a 35+ offset and have plenty of room to spare. you must have a huge offset or drop or you're issue may be elsewhere
Old Jul 31, 2009 | 07:05 AM
Huey52's Avatar
Registered Zoom Zoomer
There's no reason for 245x40's to be rubbing on 18x8.5 RPF1's even with a modest drop. You must have an extreme drop and/or a very aggressive custom offset (lower number than 35+).
If extremely lowered the solution is obvious, raise it up a bit to afford better suspension clearances for imperfect roadways.
If extreme offset then you'll need to roll your fenders.
If not excessively dropped or offset then you have bad shocks and/or springs.
We obviosuly need more info on your setup.
Old Aug 1, 2009 | 09:33 PM
offset of the wheels are 40.
my car is not lowered at all.
my rear ones are rubbing really bad while the front ones aren't that bad.
rear tires rub while going over the bumps and turning.
while i have 3 people including me inside the car, the rear tires will rub even worse than before.
Old Aug 1, 2009 | 09:46 PM
I8U's Avatar
I8U
You need to get under the car and see what is really rubbing or hitting. There really should be no reason for you to rub at all with that offset and tire size even with a fully loaded cab.
Old Aug 1, 2009 | 10:08 PM
i think i should take a picture and post it here cuz its kinda hard to describe
Old Aug 1, 2009 | 10:16 PM
Yeah please do... You shouldnt be anywhere near close to rubbing with those modest wheel/tire specs
Old Aug 1, 2009 | 11:06 PM
wow,
does everyone weight 400 lbs or something??
Old Aug 1, 2009 | 11:25 PM
other question. is it because the fact my 8 has a regular suspension (16 inch rims) unlike other 8s that has sport tuned suspension?
Old Aug 1, 2009 | 11:26 PM
Originally Posted by swoope
wow,
more like 500 pounds each LOL jk.
Old Aug 1, 2009 | 11:35 PM
vbrad26's Avatar
Lurker McNasty
sure its not a -40 offset? lol
Old Aug 1, 2009 | 11:41 PM
wow,
that changes the rules a bit. i have no idea what the tire height is on the 16 inch tires.
maybe you could measure it.. or set one old wheel with tire up next to one of the new wheel with a tire and see if there is a difference.
just a simple idea. or you could use a tape measure.
Old Aug 2, 2009 | 02:54 AM
RickA's Avatar
Party.
A very very small bit... the wheel heights cant be different enough to make an 18" rim with 245/40 tires rub. I'm agreeing with everyone here that it's gotta be something else. You shouldn't be rubbing on stock suspension with 8.5 +40 wheels... On stock suspension I BARELY rubbed with 10.5 +30 wheels in the back...
Old Aug 2, 2009 | 07:37 AM
c41250n's Avatar
something is wrong with your car!!
Old Aug 6, 2009 | 12:06 AM
base automatic with 16inch wheels. who knows the specs on that?
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
