Finally Oil Cooler Fan Kits!!
Old Jul 22, 2009 | 06:51 PM
Race Roots's Avatar
Former Sponsor
Now Available!
One of the most common causes of RX-8 engine failure is excessive heat. High temperatures have long been the enemy of rotary engine longevity and performance. There are many effective modifications that can increase the cooling capacity of your RX-8s primary cooling system – the engine coolant, water pump and radiator. Until now there have been few ways to address the secondary cooling system – the engine oil and coolers.
The oil system of the Rotary provides approximately 30% of the engine cooling.
During normal operation engine oil is routed through the eccentric shaft into the rotors to provide cooling and lubrication. When engine oil temperatures are reduced, more heat is removed from the engine reducing demand on the primary cooling system.
Since the RX-8 does not come equipped with an oil temperature gauge most owners are not aware there is a problem until it’s too late and they are facing engine failure or low compression.
With another hot summer upon us oil temperatures in street applications are extremely high and customers are reporting engine operating temperatures in the 240f range. If the past is any indication, this will lead to yet another round of summer engine failures.
How it works:
During low vehicle speed or in stop and go traffic the lack of airflow does not promote efficient heat transfer from the factory oil coolers. Using our oil cooler fan kit (or kits) with the factory installed oil coolers significantly improves air flow across the oil coolers lowering oil temperatures and assisting in the reduction of engine operating temperatures.
The kits are available in driver, passenger, or two sided configurations to meet any level of cooling needs.
The passenger side kit is compatible with automatic transmission cars as well providing additional transmission cooling which can extend transmission life.
Protect your investment by lowering engine oil temperatures and extending engine life.
Helps prevent:
* Overheating
* Low RPM drivability issues
* Heat related performance loss
* Lower engine compression
* Issues with seals
* Rapid deterioration of water jacket seal (the equivalent of head gaskets)
Kit Includes:
* High flow fan
* Custom RX-8 specific fan shroud
* Mounting bracket
* Smart fuse holder
* Heavy duty relay
* Plug & play harness
These kits are ideally suited for daily driven and autocross applications!
Kits are on Sale now for $175 and can be purchased via our site here.
Old Jul 22, 2009 | 06:58 PM
05rex8's Avatar
sold the 8... :(
wow nice!
Old Jul 22, 2009 | 07:00 PM
Brettus's Avatar
Boosted Kiwi
/\ signal off the first stage rad. fan relay would be a good option ......
Old Jul 22, 2009 | 07:27 PM
Race Roots's Avatar
Former Sponsor
Yes, it can be wired two ways.
They can cycle on and off based on engine temperatures and vehicle speed and will continue after the engine is turned off.
or
It can be wired via Ignition when the vehicle is turned on.
Old Jul 22, 2009 | 07:46 PM
lilring's Avatar
Finally a MT
Very nice.. Good job brice! I might be ordering one after I move to TN
Old Jul 22, 2009 | 07:52 PM
syntheticdarkness's Avatar
ThEy MaDe Me Do It
Not right now, but in time I'm going to need two. One question though, when you buy these kits should we cut the vents on the inside of the fender a little bigger since it will be forcing more hot air out now?
Great job by the way!!!!
Old Jul 22, 2009 | 08:37 PM
rodjonathan's Avatar
silent assasin
these will be on my to do list
Old Jul 22, 2009 | 09:04 PM
OMG, perfect timing. $175.00 for each side? Discount for both? I didn't know you guys had a fan control kit either.
Also, it says plug and play. What does it plug into?
Old Jul 22, 2009 | 09:38 PM
TheBurkeMan's Avatar
how come it says 175 here but but 135 on the site... and is that for one or a pair
Old Jul 22, 2009 | 09:56 PM
czar's Avatar
Almost boosted
i guess i know where all my 3 month bonus is going to ~_~,
will i ever own furniture such hard profound questions, does the front bumper need to be removed ? or just the plastic fender liner (i ask because i forgot to leave slack in the cable for the jamming heads >_>)
Old Jul 22, 2009 | 10:03 PM
stanknasty56's Avatar
8lover
wow very nice, i like the idea.
Old Jul 22, 2009 | 10:04 PM
Spinning Sushi's Avatar
I <3 Sushi
I've thought up of this idea about two years ago but I couldn't find a fan small enough to go behind the oil cooler from my local auto-parts store.
Old Jul 22, 2009 | 10:12 PM
quazmosis's Avatar
Chode
I like this. Easy to instal yourself? Come with directions?
Old Jul 22, 2009 | 10:48 PM
wow, nice
I think Im ok ... I think my cooling system is fine for now ...
if I have the extra cash, why not ?
Great work man !
Old Jul 22, 2009 | 10:55 PM
czar's Avatar
Almost boosted
heh, down here in texas its been hot, everday is a 100+F day. a little extra cooling never hurts, was thinking of water mister on them
Old Jul 23, 2009 | 01:14 AM
Flashwing's Avatar
3-wheeler
Brice I have a question as well if you don't mind...
I know you removed the wheel well lining to take pictures but are you able to still use the wheel well plastic? I always found it to be a tight space but I couldn't tell by your pictures.
Great product! I've always felt fans were an excellent idea because it gives you extra cooling when you need it but you can turn them off in the winter or colder months.
Old Jul 23, 2009 | 02:27 AM
matt13b's Avatar
Can these be shipped to Australia??
Old Jul 23, 2009 | 03:49 AM
foo77's Avatar
4th batch : Apr 03'
great product +1 what Flashwing said, pics with all cover up will be great as for the plug and play, do you mean it will work like mazsport fan kit before? i think that will be great too, where it can detect when it should on and off by itself
Old Jul 23, 2009 | 04:49 AM
bse50's Avatar
#50
you should recommend to open the air vents in the wheel well too imho Not much, slightly opening them could avoid the "rebound" of the air pushed by the fans
Old Jul 23, 2009 | 08:37 AM
Race Roots's Avatar
Former Sponsor
We ran this on a local car and we experienced a 30 Deg. F drop in Oil Temps. we did modify the ducts behind the wheel liner to increase flow.
Of course PM me for ordering options and discounts.
You are mixing the oil cooler fan kit and the standard fan kit.
Front bumper doesn't need to be removed, it just makes for an easier installation, it is recommended of course.
Absolutely it comes with directions and I think it is easy.
Yes sir as I responded above it is not necessary but we did to increase flow.
Absolutely. Orders can be placed on the website.
Correct Plug and Play and automated as well...
Thanks for all the positive feedback we have two more products to wow you, that go hand in hand with this as well
I am more excited about those releases because they are more eye catching if you know what I mean
Old Jul 23, 2009 | 08:53 AM
fastlaneracing's Avatar
Rotor User
This is nice! I'll be soon ordering these fans.
Old Jul 23, 2009 | 11:31 AM
lepichichi's Avatar
I LuV mY Rotary....
wow this is awsome, this is defenetly on my next to get list!
Old Jul 23, 2009 | 03:23 PM
ChrisRX8PR's Avatar
13B-RE
I have an engine oil temp and I completely agree with the oil temp issue. Its great while I am driving...but when I sit at a stop light...it starts to climb considerably fast. This cant be good for the engine.
I am interested in what "two other" producs you are talking about...if its improved replacement oil coolers...I am in...
Chris
do those mounting spacers relocate the bottom of the oil cooler below the front bumper opening?
Old Jul 23, 2009 | 05:27 PM
04RX8man's Avatar
Rotary Powered Countryboy
Yes I think I need some! haha
