Loss of power....2-3 seconds crank
Old Jul 16, 2009 | 05:40 PM
chabinator's Avatar
I bought a mazda 2004 rx8 95k miles 2 month ago
I takes 2-3 seconds to start
and now I feel a loss of power under 4k rpm
I installed new sparkplugs
I just ordered new coils...should arrived in a week or two
I have read that the 2-3 seconds slow start can be caused by the original starter that is weak
My starter have just been reconditionned (because i broke my clutch and it hurt the starter to so i had to repair it).....still a slow start....
Maybe the loss of power i caused by low compression...so new engine possible....I have read that when they installed a new engine, it comes with an upgraded starter
OK..what should I do?
1. Install coils and see if my issues get solved
2. If unsolved, go to the dealer and ask for a compression test, so maybe a new engine and a new upgraded starter for free and all problems get solved
advices please
thanks
Old Jul 16, 2009 | 06:17 PM
mzrx's Avatar
crank issue -- how old are your battery?
power loss -- it could be any thing, if you can get a compression test under warranty then go for it.
Try cleaning your throttle body, it might be sticky and will probably solve other issue that you have not run into. Car with high mileage can have all sort of problems if the previous owner does not keep it well maintained. Does the car have any maintenance record you could look at to see if their was any past issue that was not taken care of the car was sold to you?
Old Jul 16, 2009 | 06:21 PM
Hoss's Avatar
I dont think a 2-3 second start is long by any means... Mine has new plugs and coils and still has occasional long cranks when starting hot.
And as for the power loss, the car doesnt really have power under 4k rpm :laugh:
Old Jul 17, 2009 | 02:11 AM
volcomx31's Avatar
Silver Power
hoss is right haha..just do a tune up
Old Jul 17, 2009 | 03:35 AM
Brettus's Avatar
Boosted Kiwi
95k miles , might be time for a de-carb .
then do a compression test
Old Jul 17, 2009 | 09:15 AM
I8U's Avatar
I8U
Power loss under 4k...hmmm 95k on the motor. I bet it has to be the fuel pump or clogged primary fuel injector. Try there first. Had the same issue with mine, ended up being primary injector.
Old Jul 22, 2009 | 05:37 PM
rotornut's Avatar
Check this thread: "Strange power loss" by aka_rob. He got the same problem we have and they discussed it a lot. Did you manage to fix it?
Old Jul 26, 2009 | 11:22 PM
chabinator's Avatar
Power loss solved!!!! One plug wire was disconnected!!!!!!!
Vroom vroom!
For the long crank start, it helped a little bit too......just bought a used updated starter 104$us shipped to montreal
Hope it will fix the long start problem...
thanks guys
Old Jul 27, 2009 | 12:19 AM
I was about to say check your plug wires make sure they're secured cuz u said u just changed plugs.
glad u found the problem
Old Jul 27, 2009 | 12:23 AM
cfm251's Avatar
Vroom vroom!
thanks guys
WIN
Old Jul 27, 2009 | 01:36 PM
As long as your at it.........................
Clean the MAF
Old Jul 27, 2009 | 09:02 PM
chabinator's Avatar
maf already cleaned and just decarb the engine!!!
vroom vroom vroom
RevMeHarder
Jun 1, 2026 02:30 PM
DylanForbes
25
Oct 31, 2017 05:47 PM
Zube6115
Sep 30, 2015 12:57 PM
Draken
Sep 21, 2015 06:14 PM
jtdwab
Sep 12, 2015 04:57 PM
