What clutch?
Old Jul 13, 2009 | 10:27 PM
J_Owens's Avatar
Owens-RX-8
What clutch?
I was thinking of upgrading my clutch to something that will grab alot better at high rpm with out grinding, because going to second at high rpm if grinds the sh** out of second gear, so I am thinking of getting something that wouldnt do that, any good ideas? anyone change there clutch out to something like that? Any imput would be great thanks.
Old Jul 13, 2009 | 10:31 PM
dozer's Avatar
on his 3rd rx8
your clutch is most likely fine, its your synchros that might be shot...anyways the exedy stage 1 is perfect
Old Jul 13, 2009 | 10:33 PM
J_Owens's Avatar
Owens-RX-8
ok cool thanks
Old Jul 13, 2009 | 10:47 PM
WingleBeast's Avatar
HAVOC
not sure the grinding is anything to do with the clutch as much as it is asking the syncros to do too much
Old Jul 14, 2009 | 01:58 PM
^^^ listen to this guy.
It could save you a LOT of money.
Old Jul 14, 2009 | 06:28 PM
J_Owens's Avatar
Owens-RX-8
ok sounds good, and yeah i put redline in the tranny at about 60k. i alosj ust found out my hydraulic clutch hose is leaking and need to replace it, could that cause this issue as well? has anyone else had this issue?
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
