Running rich after exhaust and midpipe install.
Old Jul 7, 2009 | 05:41 PM
Renesis 8's Avatar
I have an hks hi power exhaust and i recently put on an agency power midpipe. Now my car smokes when i start it and it smells like un burnt fuel all the time now.
Old Jul 7, 2009 | 05:42 PM
xun4gvn4everx's Avatar
True love is blue x2
Was the midpipe the cat delete?
Old Jul 7, 2009 | 05:47 PM
I8U's Avatar
I8U
Reset your fuel trims and go from there. It will always smell like raw fuel now, since you have the midpipe on.
Renesis 8's Avatar
yeah it was.
Old Jul 7, 2009 | 05:53 PM
Renesis 8's Avatar
How do you reset your fuel trim.
Old Jul 7, 2009 | 05:56 PM
expo1's Avatar
He's as bad as Can
you need to purchase a Cobb Accessport and reprogram the cars ECU
I8U's Avatar
I8U
There are two reset procedures, one for the NVRAM and the other for the KAM. Neither will erase your radio presets.
1) With the key in the off position, press and hold the odometer reset button and turn the key to on;
Continue to hold the odo button until the odometer reads "TEST" and then release.
2) Turn the key to off and repeat step one.
This will reset the entire PCM except the KAM which contains the sensor profiles amongst other things. You can reset it with the familiar procedure:
1) Turn the key to on
2) Depress the brake pedal rapidly 20 times in a row until the oil pressure gauge sweeps to halfway and back again.
Old Jul 7, 2009 | 05:59 PM
Gatta love the smell of no cat. mmmmmmmmmmmmmmmmmm. that'll wake you up in the morning! Or kill you if you stay in the garage to long.
Old Jul 7, 2009 | 06:13 PM
Renesis 8's Avatar
Ill give that a try. thanks I8U. Yeah i do love the smell of no cat
Old Jul 7, 2009 | 06:18 PM
Easy_E1's Avatar
You should love the fire that comes out of your exhaust now too.
Old Jul 7, 2009 | 06:20 PM
Brettus's Avatar
Boosted Kiwi
normal - what were you expecting ?
unless you are logging afrs you and have actually seen that it is running richer than it was I suspect it is just the same but because of the cat delte you now smell the gas ....
Old Jul 7, 2009 | 06:27 PM
dozer's Avatar
on his 3rd rx8
i like my midpipe too
Old Jul 7, 2009 | 06:36 PM
Spinning Sushi's Avatar
I <3 Sushi
OP - It is normal.
It runs rich to help preserve the cat. Resetting the KAM and PAM won't do anything much to help how rich it is running.
Old Jul 7, 2009 | 07:19 PM
Like it rich and enjoy the flames!!
Old Jul 7, 2009 | 07:56 PM
04RX8man's Avatar
Rotary Powered Countryboy
8 runs pig rich...enjoy flames for now or buy the AP and lean out the tune....about the only thing to do!
Old Jul 10, 2009 | 03:12 PM
RX8YA's Avatar
WAH WAH WAH
I have a MM AP i just installed my Agency power midpie dual resonated today....LOUD lol but anyway should i send away for calibration right away or drive it a bit before? Is there anyway to lower the afr myself in the meantime? What are optimal AFR's?...im searching but seeing alot of variance.
Old Jul 10, 2009 | 04:52 PM
actually it's the result of not having a cat converter, congrats on turning your car into a polluting POS, I really wish the EPA would start hunting down and confiscating cars and throwing people in jail for blatantly intentional pollution mongering. There's no excuse for it, the people who do this are too cheap and uncaring to give a damn, scumbags...
Old Jul 10, 2009 | 05:07 PM
Brettus's Avatar
Boosted Kiwi
hmmm - don't hold back Team ..
Old Jul 10, 2009 | 06:19 PM
Renesis 8's Avatar
Oh no TeamRX8 said we are scum bags. Better get rid of the midpipe
Kanthinar
Dec 21, 2015 01:24 PM
9krpmrx8
Nov 5, 2015 11:45 PM
PTQLam
Aug 16, 2015 05:40 PM
TheWhiteAce
Series I Engine Tuning Forum
Aug 6, 2015 02:26 PM
yapakanichi
16
Jul 28, 2015 03:44 PM
