failiure at springs
Old Jul 4, 2009 | 01:27 PM
chino0314's Avatar
failiure at springs
so i was attemping to install some tein springs and um well pictures speak for them selfs any idea on how to fix this
Attached Thumbnails failiure at springs-2009-07-04-14.02.55.jpg   failiure at springs-2009-07-04-14.03.19.jpg   failiure at springs-2009-07-04-14.02.31.jpg
Old Jul 4, 2009 | 01:37 PM
Stingray's Avatar
Are you having trouble getting the bottom of the strut lined up with the control arm? It is kind of hard to tell what you still have connected. Did you pop the upper ball joint apart?
Old Jul 4, 2009 | 01:39 PM
chino0314's Avatar
im having problems taking he strut out im trying install springs
Old Jul 4, 2009 | 01:59 PM
Stingray's Avatar
Here is a pretty good step-by-step.
http://www.hi-impact.org/ryang/modif...ock_front.html
You might have to go to an autoparts store to rent a ball joint separator. Good luck and if you have any other questions ask!
Old Jul 4, 2009 | 02:04 PM
chino0314's Avatar
FL
thanks sting ray damm no car for today just started rain......
MIAMI FAILS AT WEATHER
Old Jul 4, 2009 | 02:08 PM
Stingray's Avatar
Ya I was going to help set-up the firework show for tonight and then it started raining. I really didn't want to go set fireworks up in the mud haha. In that write-up you don't have to separate the ball joint. I did and it made it easier it seemed like. Just took a lil bit more time. I did the front in about an hour and half. That is from jacking it up to setting it down. You should be able to do it in under 2.5 hours. Good Luck
Old Jul 4, 2009 | 02:12 PM
chino0314's Avatar
Thanks much
Old Jul 4, 2009 | 02:34 PM
NgoRX8's Avatar
it's better if it's a two person task. one person pushing down on the brake assembly and control arm while the other tries to maneuver the strut out.
Old Jul 4, 2009 | 02:53 PM
chino0314's Avatar
yup realized that about 2.5 seconds after starting lookslike ima have to call in a friend and looks like pizza and beer is in order
Old Jul 4, 2009 | 06:58 PM
you're not suppose to take the top shock nut loose until after removing the entire assembly from the car and compressing the spring, fortunately you managed not to kill yourself yet, it's still a possibility though because you created a pretty good mess of things by doing so....
Old Jul 5, 2009 | 05:47 PM
I8U's Avatar
I8U
^+1
Old Jul 5, 2009 | 05:49 PM
Spinning Sushi's Avatar
I <3 Sushi
Take off the two top arms. That will make your life a lot easier.
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
duworm
Oct 1, 2015 04:57 PM
Turman-ator
11
Sep 22, 2015 11:22 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
