View Full Version : Premixing Options
Dear All,
I am located in Pakistan, and the average temp here in daytime nowadays is 100 F to 110 F (around 40 C).
So heat is a major concern here, and I would like to take all steps possible to make sure my engine stays intact.
I was reading up on how premixing is helpful with engine life, and went out in search for 2 stroke oils, and only found two in the market.
One is from shell - Shell Advance 2 Stroke Engine Oil (link below) and one from a local company (PSO)
http://www.shell.com/home/Framework?siteId=pk-en&FC2=/pk-en/html/iwgen/leftnavs/zzz_lhn4_0_0.html&FC3=/pk-en/tailored/shell_for_motorists/motorcycles/advance/product_range/products_2t_ga_2101.html
Has anyone used this for premixing ? Should i try it ? Any comments would be appreciated.
Thanks.
BigMikeATL 06-26-2009, 02:25 PM I would suggest searching through the main Premix thread. There are lots of suggestions.
http://www.rx8club.com/showthread.php?t=99636
The one thing to note is that premix may help with lubrication, but you still have to deal with the heat. You may want to look into an improved radiator and oil cooling.
Search the Tech Garage and DIY forums for "cooling" to see what comes up. There are lots of useful posts that may point you in the right direction.
What grade of oil are you running in the car? I would recommend 10w40 or maybe 20w50.
04RX8man 06-26-2009, 07:10 PM Premix WILL help with engine lubrication(apex) but as for cooling will not help. Like said above a radiator and better/more oil cooling will help with the heat issue
as for that premix I have not used it but it looks to be ok....I know some users of premix on her order some online in cases but I'm not sure how that works for you over there!
Razz1 06-26-2009, 07:19 PM :eek:! Do not use that stuff!
You can only use synthetic premix!
04RX8man 06-26-2009, 07:47 PM ^I've used non-synthetic before and it worked fine...now I ONLY use synthetic
swoope 06-27-2009, 02:56 AM ^I've used non-synthetic before and it worked fine...now I ONLY use synthetic
you said you dont premix!!! god get your story straight..
and read the posts..
beers :beer:
swoope 06-27-2009, 03:01 AM gX1,
if you are to premix two major points..
1 find a synthetic 2 stroke oil.
2 mix it with gas before you dump it in the tank..
that will go a long way..
if you can get this, it is a very good choice..
Idemitsu Racing Rotary Fuel Lube (Premix) - Synthetic Blend
also change the oil in the motor often..
beers :beer:
04RX8man 06-27-2009, 10:37 AM No I meant that I have not used THAT shell premix...I have been premixing for about 20k miles now with Pennzoil Marine outboard
Thanks for the suggestions on the premixing. I will try and get a premix oil imported here, lets see how that goes.
Any suggestions on which radiator is best ? BHR, Koyo or RE-medy?
Also, should i get a 2nd oil cooler ? : http://www.mazmart.com/ItemDetail.aspx?id=317
04RX8man 06-27-2009, 05:44 PM BHR radiator is the best of those 3
yes a 2nd oil cooler will help with cooling alot...hell get 3 of them hahah!!!
swoope 06-27-2009, 11:06 PM Thanks for the suggestions on the premixing. I will try and get a premix oil imported here, lets see how that goes.
bhr and mazmart are the radiators to have, all the rest really do nothing.
and yes get the second oil cooler..
beers :beer:
nycgps 06-28-2009, 12:32 AM BHR is made by Griffin. Very famous Radiator maker. They usually do Rads for High HP muscle cars. CRH asked Griffin to have less fins for more efficient air flowing. Perfect fitment.
Re-Medy is made by Ron Davis. another famous Radiator maker. same type as Griffin. Also this radiator is the same as Mazda's competition Radiator. Perfect Fitment.
Koyo? Well, if you have a Race car with almost nothing blocking behind the rad. Then its a good choice. For Stock cars. nope. Dont get it.
RX-8.40 06-28-2009, 01:26 AM gX1,
beers :beer:
I found a (Honda Racing hp2 2-stroke premix oil) at the local Honda shop, dirt bike forums say it burns super clean. Does this meet the right specs for premixing my rx8?
http://www.rockymountainatvmc.com/viewLargerImage.do?stockId=99098&navType=type#OtherImages
Thanks for the advice!
swoope 06-28-2009, 01:31 AM -----------------------------------
likely,
i did a qt of bell ray silly super expensive oil. long story..
but you have to put the cost into perspective..
i think i can say i have premixed more types than most.. and really i have, and suffered from it..
have also premixed with fp1 a good combo..
right now mmo suits my needs..
beers :beer:
You should NOT be using ANY Marine Type 2 stroke oils meant for Outboard motors or Boats as a pre-mix for your rotary..
Use basically anything for 2 stroke engines apart from Marine.
bse50 06-28-2009, 05:25 AM Have you got access to Motul products? the 600 (dicontinued?) and the 700 are pretty good premix 2stroke oils. I love them.
As long as it is not a marine or aviation oil for constant rpm operation then you will be fine.
Avoid the castrol TTS if you can, that oil really produces loads of deposits.
Keep these DIY in mind too, they are great:
http://www.rx8club.com/showthread.php?t=168650
http://www.rx8club.com/showthread.php?t=123524
Replacing the front plastic grille with a real one will help, i did replace the 2 exhaust fake grilles as well and they help with trunk temperatures a bit :)
04RX8man 06-28-2009, 10:56 AM I have been using Marine the whole time and no problems especially since i got some non marine and read the bottle and it said the same numbers and stuff....
