Question about spring install.......
Old Jun 25, 2009 | 06:59 PM
LURCH634's Avatar
Wher'e Going Streaking
SO I INSTALLED MEGAN RACING SPRINGS AND I PUT THE SHORTER ONES IN THE FRONT AND THE LONGER ONES IN THE BACK, BUT THE FRONT LOOKS WAY LOWER THAN JUST 1.75 INCHES. COULD I HAVE PUT THEM ON BACKWARDS??
Old Jun 25, 2009 | 07:48 PM
LURCH634's Avatar
No one knows?
Old Jun 25, 2009 | 08:03 PM
dozer's Avatar
on his 3rd rx8
werent the springs labeled?
Old Jun 25, 2009 | 08:20 PM
LURCH634's Avatar
no they where not
Old Jun 25, 2009 | 08:47 PM
did you preload?
Old Jun 26, 2009 | 02:48 AM
Originally Posted by Jedi54
did you preload?
that would make it worse..
and yes it seems you put them on backwards..
Old Jun 26, 2009 | 04:54 PM
LURCH634's Avatar
Good news. I tried to swap them and i must have done it right to begin with because the ones i thought i could have put wrong was way to short for the rears
Old Jun 26, 2009 | 05:07 PM
usually all springs have an F or a R in the model # on them to tell you front to rear. I know for a fact the Tanabes and the Teins do and from what i can remember so did the Eibachs. Plus its obvious when you pull the stockers out.
Old Jun 26, 2009 | 05:42 PM
Spoolin8's Avatar
With these springs how long can you expect your stock setup to last before wearing down and needing to be replaced?
Old Jun 26, 2009 | 07:22 PM
Just drop spring won't hurt anything. It may wear the stock shocks out early but my stock shocks last almost 70k on my first drop springs. The factory shocks are Tokico performance shocks.
Old Aug 9, 2009 | 10:10 PM
mkmike103's Avatar
How much longer are the rear springs than the front springs?
Old Aug 10, 2009 | 12:16 AM
Few inches (2-3 I would guess).
Old Aug 10, 2009 | 12:50 PM
mkmike103's Avatar
Thanks for the response. I ask cause I bought a set from a member on here, never installed. All the springs are very similar. It does look like two of them are shorter by like less than an inch, but that didn't seem like a whole lot. Anyone with these springs remember when they installed them?
Old Aug 10, 2009 | 03:03 PM
Yep, shorter in the front, longer in the back. Most aftermarket springs have an "F" for front and "R" for rear on the springs.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Paul_Y
Sep 21, 2015 02:23 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
