View Full Version : Help !! don't wanna CEL with new Midpipe???
realBlackSunshine 06-19-2009, 09:43 AM Just bought a new mid-pipe cat delete no RES, from a member here . now how do I avoid a Cel . I know I have seen a DIY for this but can't find it, I need to put a spacer in for my O2 sensor ............plaese help???
try this
http://www.scoobymods.com/rear_o2_sensor_fix-t5468.html?t=5468
dozer 06-19-2009, 12:02 PM for some reason my CEL went off a couple of weeks ago and hasnt returned...:dunno:
04RX8man 06-19-2009, 04:35 PM Accessport!
dannobre 06-19-2009, 04:55 PM ^^ Basically :) The CEL will be there cause there is no CAT
...deal with it...or mask it with the Accessport
The other options usually don't work...so don't waste your money
dozer 06-19-2009, 05:15 PM or you MIGHT get lucky like me and the CEL will accidentally turn off :)
jessedrifter 09-24-2009, 02:55 AM theres no way just to clear the code? foreverrr
Jon316G 09-24-2009, 03:06 AM theres no way just to clear the code? foreverrr
Nope.
Buy an AccessPort or use black electrical tape to cover it and you'll never see it ;)
@!!narotordo 09-24-2009, 06:33 AM What about removing the vfad. I did that and caped it and my cel has not come back on.
Jon316G 09-24-2009, 06:54 AM What about removing the vfad. I did that and caped it and my cel has not come back on.
:uhh: What does that have to do with the O2 sensor?
DarthRX8 09-24-2009, 07:09 AM ^^ Basically :) The CEL will be there cause there is no CAT
The Accessport can mask a CEL?
Haha, beat Laythor and Flashwing! :lol:
40thrx8whynot 09-24-2009, 08:14 AM dose tape really work ?
Vyndictive 09-24-2009, 08:20 AM well, instead of the Check engine light on your dash, you have electrical tape. . . the light is still on, you just have tape over it so you can't see it. . . I can write a DIY if you'd like? :cwm27:
TeamRX8 09-24-2009, 08:43 AM just kill yourself, now .....
9krpmrx8 09-24-2009, 08:45 AM Yeah without the Access port it will stay regardless of what you do.
Vyndictive 09-24-2009, 09:36 AM just kill yourself, now .....
wow, that's a tad harsh, even for the RX8club!
Jon316G 09-24-2009, 03:43 PM well, instead of the Check engine light on your dash, you have electrical tape. . . the light is still on, you just have tape over it so you can't see it. . . I can write a DIY if you'd like? :cwm27:
I actually thought that was pretty funny. :lol2:
Spoolin8 09-24-2009, 03:57 PM The back o2 sensor is just for making sure the cat is in good condition right? I know our cars have a wideband setup and i want to make sure that its not the same sensor, because if you use the spark plug trick and that sensor is the wideband one then your messing with the readings and fuel injection.
Jon316G 09-24-2009, 05:23 PM ... because if you use the spark plug trick...
Let us know how that "trick" works out for you ;)
