middle rear seat 8" sub
Old Jun 18, 2009 | 03:19 PM
rx8snowboard's Avatar
rx8snowboard
Hey guys, I was thinking of putting in a 8" sub between the two rear seats like I have seen in some of the newer eclipse's... I don't want to lose any trunk space so thats the reason I want to do this plus I have the bose stock speakers and I just want a little more bass but not enough to shake my license plate loose . Any idea's, thoughts, price guess, type of sub, type of amp?
Old Jun 18, 2009 | 04:15 PM
nuke0907's Avatar
Never Blend In
there are already a few threads about this.
Old Jun 18, 2009 | 04:31 PM
Tamas's Avatar
Registered Lunatic
I used to have one like that.
https://www.rx8club.com/series-i-interior-audio-electronics-24/installed-custom-stealth-sub-box-between-rear-seats-mp3-player-amp-38560/
It was very pretty but (not surprisingly) it didn't go low enough. The one 8" sub with such a small box is simply not sufficient IMO (and I'm not a bass junkie by any means).
I was not happy with it's performance, so I sold it. Lost plenty of money on the transaction. I'm now much happier with the 4080 box and the 10" Infinity Kappa sub I have, and it doesn't really take that significant trunk space at all. I'd advise to rather go this route than the 8" sub.
Old Jun 18, 2009 | 07:00 PM
WikkedOne's Avatar
Deals on wheels
Listen to Tamas - he is wise beyond his years.
Old Jun 18, 2009 | 08:22 PM
rXter's Avatar
Yep. I put a 10" Basslink in the trunk. Takes up almost no room and sounds great.
https://www.rx8club.com/showthread.p...light=basslink
Old Jun 19, 2009 | 12:14 AM
rx8snowboard
https://www.rx8club.com/showthread.php?t=38560
I know some friends that could make this happen for about 200 with a MTX sub and box with a good amp, I was worried about how little a difference this would make and I do want that lower bass to come out... do you think your sub and amp was just not putting out enough or the difference in sound quality is what you are talking about? I have had 12's and I have had 10's and personally I like the 10's better (or just one 10 to be exact) but I have never had a stock system that sounds this good to me so I don't know how much I need to improve on it, also I have never paid for my systems to be put in and I have never thought of putting in a 8" the only reason I am thinking about it now is to not loose the little trunk space I have. Thanks for the input, your knowledge does seem to exceed the rest
Old Jun 19, 2009 | 03:31 AM
Tamas's Avatar
Registered Lunatic
What I meant is that the 8" sub and the smallish box combined did not give enough deep fill what I was after. The amp is not the problem, because I'm still using the very same amp with my current sub, and that setup gives me what I need. I'm driving a 10" Infinity Kappa Perfect woofer in a 4080 enclosure.
The box really doesn't take much useful space, this is how it looks now. As you can see, it is in the corner, so the lost space is negligible.
And thanks for the kind words, but my knowledge about this stuff is really minuscule. There are plenty of people here who know very well what they are talking about when it comes to audio stuff - read back the posts and you'll quickly figure out who they are
Old Jun 20, 2009 | 12:44 AM
rx8snowboard
Did you have the amp and sub running off your stock amp or do you have a aftermarket deck with audio outputs?
Old Jun 22, 2009 | 12:41 AM
Tamas's Avatar
Registered Lunatic
I have the base radio, speakers were replaced with components and the amp is used with line level converters I believe (didn't install it myself as it was described in the linked thread).
Old Jun 24, 2009 | 02:04 AM
rx8snowboard
so I don't have the money for either right now but it sounds like if I did the midmount it would not be as clear of a sound and maybe not enough bass... but the 10" is going to run me about 1000 dollars installed... decisions decisions...
Old Jun 24, 2009 | 03:20 PM
always.anthony's Avatar
is looking for his torque
do your self a favor and go with the 8 inch if you decide to go with the in between the seats route. i got a ten inch, and am having to do a lot of custom work. but i would never settle for an 8 anyways :P
Old Jun 24, 2009 | 03:58 PM
cornholio135's Avatar
SARX
Here is an easy solution...
1- 8" self amplified Bazooka Bass tube... It would fit against the backseat and take up minimal room. Do not let the 8" size fool you. It's sound is equilvalant to a 10" regular sub box...
http://www.bazooka.com/products/mobi...ified-Tube-P38
Old Jun 24, 2009 | 04:59 PM
firebirdude's Avatar
User and Abuser
My father has an 8" 100W Bazooka tube in the trunk of his Audi S4 (well built heavy rear seats) and it's PLENTY of bump to round out your music and then some.
Old Jun 25, 2009 | 10:37 AM
rx8snowboard
Thanks guys, I guess I want to hear the 8" before I decide to do this... any ideas on where I can listen to one? I went to best buy and they don't even sell them, also went to laketown speed and sound and they said they don't have them but can get them but he recomended the 10 lol
Old Jun 25, 2009 | 11:04 AM
cody6766's Avatar
It's going to be hard to find a shop that has an 8" sub installed in a manner that will really show off what it's capable of. It'll need to be in a bigger box (bigger for an 8, not a big *** box) and in a small'ish room. An 8" sub in a standard listening room mounted to the wall like the components are mounted will barely give you an idea of what it's capable of. Just be sure you get one that moves some air. An 8" sub doesn't allow a whole hell of a lot of cone area to move air (which makes sound), so it'll need to be a pretty high excursion driver to do the trick. I can't think of the names of the companies now, but look around the internet for subs with XBL^2 motors. Resonant Engineering makes (or made) them, and there are now a lot fo internet companies making them now. That motor design allows for really long throw subs with killer cone control...meaning they push a lot of air but do it with great sound quality. A lot of them are really affordable for what you get too. the only issue you may find is their size. The XBL^2 motors are inherently large, sometimes as large as the cone/basket. It won't be a 200lbs monster, but it'll be a hell of a lot bigger than a JL 8w3
Old Jun 25, 2009 | 11:12 AM
User and Abuser
Adire Audio was the inventor. Finally someone who recognizes what I'm running. lol
Old Jun 25, 2009 | 02:25 PM
faith&firepower's Avatar
My Other car's A Stryker
Thats what im running with the bose system and its plenty of extra bass.
Old Jun 25, 2009 | 03:23 PM
SARX
If you are really bold you can even mount 2 of them as I did....
Old Jun 25, 2009 | 11:15 PM
rx8snowboard
What kind of amp and box?
Old Jun 26, 2009 | 01:38 AM
cody6766's Avatar
Yup, I remember when their Brahma was all the craze. It was the car audio boner of the quarter for a while. I considered snapping one up but went with the 10w7 instead. I was sold on it when I was able to audition it back in the first year of the w7's release. I haven't turned back since. I'll have mine glassed into my trunk eventually. Right now it's in a temp wood box that snugs under the rear deck.
Old Jan 23, 2010 | 09:32 PM
rXter's Avatar
Love the rotary grill Tamas.
Dude, seriously look into the BassLink. 10", 200W, simple install (see link above) and under $200. Not as neat a finished product as the 4080, and likely not as clean, but it does the job much better than a zook tube and is a better install - takes us as little space as the 4080
Old Jan 23, 2010 | 09:40 PM
mike[piston eater]'s Avatar
O' Let's do it.
were the hell did you go thats a rip, i got a 12in 75owatt rms kicker cvx $200 dollars, hifonics 1000 watt rms zeus 2 channel amp $170, $40 dollars for wiring,
$25 for line output converter, and a zenclosure for $120 i dynamatted my whole trunk cause it rattled like crazy add it all up
total $555
i suggest you look at a different shop
Old Jan 23, 2010 | 11:12 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
try solo, I have been addicted to these subs for years.
Old Jan 24, 2010 | 12:17 AM
O' Let's do it.
solos are sick, i went with cvx cus i already had the round box,but it has the same watt handling as an l7 but moves less air obviously cause its round
Old Jan 24, 2010 | 10:35 PM
rx8snowboard
I agree that the quote I got was a rip and thats why I didn't do it lol. I like the baselink 10" idea tho...
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Olorin2
20
Mar 13, 2016 11:01 AM
nowakm99
Oct 9, 2015 07:10 AM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
