Coolant Overflow Hose Fries Cooling Fan
Old Jun 8, 2009 | 07:49 PM
Nemesis8's Avatar
Bigus Rotus
Be sure to re-plumb your coolant overflow hose to extend below your cooling fan motor and connectors. Mine was way too short!
It seems mine overflowed and toasted one of my cooling fans. I tried everything to get her to start, but alas she gave up the ghost it seems. You can see the green remnants of the coolant.
This must of caused a locked rotor amp draw or similar, because it blew the 40A fuse. Jumpered the relays, wiggled and cleaned the connectors, no go it seems.
I'll need to test the motor once I get it out of the engine bay....
Attached Thumbnails Coolant Overflow Hose Fries Cooling Fan-img_1072.jpg   Coolant Overflow Hose Fries Cooling Fan-img_1074.jpg
Old Jun 8, 2009 | 07:56 PM
G3tR3DDY2GR3DDY's Avatar
i have a few replacements if you need.
my solution was a universal AST mounted next to the ECU box and plumbed into the subframe
Old Jun 8, 2009 | 08:00 PM
Nemesis8's Avatar
Bigus Rotus
Interested. Is there a difference in the two motors? I need the passenger side one.
Old Jun 8, 2009 | 08:04 PM
dmp's Avatar
dmp
RX8 and a Truk....
WOW - very crazy.
How's things otherwise, bro?
Old Jun 8, 2009 | 08:13 PM
Nemesis8's Avatar
Bigus Rotus
Originally Posted by dmp
WOW - very crazy.
Other than I need to win the lottery to get out of debt, not much.
LOL
Old Jun 8, 2009 | 08:17 PM
Nemesis8's Avatar
Bigus Rotus
Found what I need HERE Confirmed bad motor.
Old Jun 8, 2009 | 08:19 PM
dmp's Avatar
dmp
RX8 and a Truk....
Anytime you and the misses wanna get away to (near) some of the best beaches in the world...holler!
:D
Old Jun 8, 2009 | 11:12 PM
Это интересно остаться на ИМКА
are you Russian?
Old Jun 9, 2009 | 08:01 AM
Nemesis8's Avatar
Bigus Rotus
^ Who me? Nope - born in the USA.
Old Jun 9, 2009 | 08:27 AM
dmp's Avatar
dmp
RX8 and a Truk....
are you Russian?
I have family that is russian. :D
Old Jun 9, 2009 | 08:55 PM
Nemesis8's Avatar
Bigus Rotus
In looking at the service manual, it says I need to remove the radiator with the cooling fans all together as one unit. What? Why can I not just get to them from the top?
Old Jun 9, 2009 | 09:56 PM
because the fan mounts are "stuck" on the radiator
you dont really have to take the radiator off, but you DO need to loose it a bit. which is almost same **** lol
take the fan mount out, the motor is secured by 3 screws. after that, put it back in the way it was.
probably takes about an hour or 2.
I dont think the coolant killed it tho, consider the motor itself is sealed. probably just got old and died.
Not a lot of room on the top...and you have to remove a lot more crap that way...from the bottom it's easier. Not sure if you could do one motor from the top??
Old Jun 9, 2009 | 11:30 PM
everything there is supposed to be waterproof, if your coolant didn't short it a drive in the rain would have ...
this reminds me of the "pre-mix is the evil cause of fuel pump failure" thread
otherwise, sorry for your trouble
Old Jun 10, 2009 | 08:09 AM
Nemesis8's Avatar
Bigus Rotus
Yes, it is a sealed motor that should be waterproof.
Old Jun 12, 2009 | 10:35 PM
Mercury's Avatar
RX8: God of Swiftness
:D
Your Location "Это интересно остаться на ИМКА" translates to "It is interesting to stay in EMKA"
Whattheheckis EMKA?
Old Jun 13, 2009 | 01:23 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah that damn hose is in the worst spot possible...damn mazda!
Old Jul 11, 2009 | 05:13 PM
markav33's Avatar
mark-d-markos
anyome kno the cmf or rpm of the stock fans ?
Old Jul 11, 2009 | 05:26 PM
was it like 1800 or 1250 cfm or something. I forgot.
MM should know.
Old Aug 8, 2009 | 09:06 PM
El Kabong's Avatar
I know the fan and connector are supposed to be waterproof, but are they designed to resist steam and boiling coolant? Resisting rain is no big deal.
- Kabong
Old Aug 10, 2009 | 05:14 PM
Nemesis8's Avatar
Bigus Rotus
I think my problem was a combination of all of the above. Extremely high ambients, boiling coolant, overflow hose location, etc etc.
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Nov 24, 2015 01:00 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
drlubell
Sep 26, 2015 11:58 PM
