Transmittion Oil
Old Jun 5, 2009 | 08:50 AM
RX8 NY's Avatar
Transmittion Oil
I was wondering if anyone knew how to check the level of transmission fluid for a manual transmission? I might be blind, but I can't find the the dipstick anywhere...
Old Jun 5, 2009 | 08:57 AM
dillsrotary's Avatar
jersey fresh
There isn't one
Old Jun 5, 2009 | 09:14 AM
rofl wtf ?
I want to know which "manual transmission car" has a "dip stick" to check the "manual transmission's" oil level ... I really want to know.
you're from NY where ?
Like dills said, there isn't one. want to know how? search or pm the right people ... *cough*
Old Jun 5, 2009 | 09:20 AM
Im_DANomite's Avatar
I love GOOOLD
BAHAHAHAHA, someone get this fool a clue!
Old Jun 5, 2009 | 09:28 AM
ndhoffma's Avatar
http://www.hi-impact.org/ryang/modif...x8_fluids.html
that will help explain a few things.....
Old Jun 5, 2009 | 09:56 AM
rotarygod's Avatar
To answer the question directly, manual transmission cars use gear oil. Actually some use a thin motor oil case such as Hondas but that's another topic. The RX-8 manual transmission uses gear oil. It is something that only gets replaced every 75,000 or so miles but many do it earlier and some change it later. It has no level to check. If the level gets low, you have a leak!
Automatic transmissions use ATF (automatic transmission fluid). It's very different stuff. It's thinner, red, and doesn't smell NEARLY as bad as gear oil!
Now that we've got that out of the way, the funniest thing I find is that 2 threads were started and in both transmission was spelled wrong!
Old Jun 5, 2009 | 10:44 AM
ken-x8's Avatar
Answering the specific question, you check gear oil level by removing the filler plug and sticking your finger in to see if you feel oil. The link ndhoffma gave shows where everything is. Rear end oil gets checked the same way.
Sometimes, if the car isn't exactly level, oil will run out of the filler hole. That also means it's full, and you need to put the plug back quickly to minimize the mess.
Ken
Old Jun 5, 2009 | 11:40 AM
We're all wrong.
The answer to his question should be : We have no answer for you
Yeah I can answer that for EVERYBODY. You guys know why ?
Cuz we have no idea what "Transmittion " oil is.
Old Jun 5, 2009 | 12:51 PM
ndhoffma's Avatar
its kinda like dofferental fluid
Old Jun 5, 2009 | 04:25 PM
Nubo's Avatar
Lubricious
Yep, your finger is the dipstick. Gotta check via the filler hole when the car is pefectly level, otherwise you will either think the case is low, and add oil in error -- Or you will think it is overfilled as oil comes pouring out.
In practical terms, tranny lube is not consumed. So no urgent need to check it. If you have a leak you will notice the smell. Though there are times when you might actually want to check, especially if you gave the car to some lube-shop monkeys and suddenly the tranny is making noise or something.
Old Jun 5, 2009 | 05:30 PM
rx8cited's Avatar
Senior Member
nycgps, what's gotten into your head? It's really swollen, eh?
Fine way to welcome someone to this forum with post count 2.
Originally Posted by nycgps
rofl wtf ?
oh, wait, now that you gave that lame answer to a newbie, you gotta' pick on them more ....... 'cause they're from NY???
We're all wrong.
Not everyone's a "smart" as you are. First impressions are everything. . Or maybe this is the standard way NYers greet each other .
Old Jun 5, 2009 | 10:46 PM
Nubo's Avatar
Lubricious
Originally Posted by rx8cited
...maybe this is the standard way NYers greet each other .
Correct.
Whadd'ya want, a medal?
Old Jun 5, 2009 | 10:58 PM
tunerwannab's Avatar
rofl wtf ?
The mid 90's to i think 2002 saturns have them.
Old Jun 6, 2009 | 07:31 AM
Damn. no wonder saturn is outa business now !
useless feature = increase cost for no reason = bankruptcy ?
Old Jun 6, 2009 | 08:17 AM
expo1's Avatar
He's as bad as Can
My beater, a 2000 Saturn SL 5-speed doesn't have a dipstick for the trans. The Clutch however does have its own fluid reservoir.
Edit: " I was wrong, there is a car on the road with an MT dipstick "
Old Jun 6, 2009 | 09:20 AM
Expo lokk way down on th the tranny, most people can barely reach it, and if you've never pulled it its probably all black with dirt, I usually have marks on my arm for about 30 min aft checking one.
Old Jun 6, 2009 | 09:43 AM
expo1's Avatar
He's as bad as Can
I stand corrected, its there but you can't reach it without removing something. Why go to the effort of making a dipstick you cannot reach? You can also run DEXRON III in it, strange.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
