few problems, Please give me some idea.
Old Jun 3, 2009 | 02:29 AM
superbiscuit's Avatar
TX few problems, Please give me some idea.
I had my car for year already, now its 56k miles, close to 57k. there are few "minor" problems.
my 8 is a bit shaking when I stopped car.
also, everytime when I start the car in the morning, there is like a drilling sound under the hood for couple mins.
when I release my clutch on neutral gear, car make greater noise.
Could anyone give some clue for those problems?
Do i have to change my coils, cables, spark plugs? also my clutch?
how many mile I should flush my gear box oil?
Thanks.
Old Jun 3, 2009 | 05:17 PM
spoddyandthemazda's Avatar
GoSpoddyGo!!!
Hi
I was getting a misfire on my eight as 3 coils burnt out, so was running very rough and very hard to start. i got new coils/plugs/leads now car like new again.
unless that is happening and you are not getting a flashing engine light your coils and plugs should be ok.
the early eights like mine, make a slight noise like a fan running, not engine fan, sorry closest thing i can think of when the engine is running over with the clutch out and in neutral.
when you put your clutch in, the noise goes away. i have read this on here before, but can't remember the corrct terms for it, its normal on the earlier cars.
i bought mine with 62800 miles, now 71500 and its going better than when i bought it.
i did have to replace my ignition bits, ie the parts you were asking about, but that was because the coils burned out as they can do (weak point) on the eight.
however you could try putting your clutch in when starting and try letting it out and in to see if noise goes away, comes back etc which should be happening. also try taking your plugs out and cleaning them if brown should be ok, just clean up, if black then bad.
but are you idling ok, revving smoothly?
Old Jun 3, 2009 | 05:24 PM
cyclone1208's Avatar
you probably have a cracked motor mounts....I had the same symptoms during a stop too......have them replaced and your car should be running like new
Old Jun 4, 2009 | 09:57 AM
thank you guys... I guess I have to go to dealer and check it. ^__^
Old Jun 4, 2009 | 10:41 AM
RyansRx8's Avatar
Brettward is/has a G
I have a chatter noise when im in neutral and clutch is all the way out but once i push it in it does go away...its in the shop right now getting fixed...they said there replacing the bearings, most likely the throw out bearings....I miss it
Old Jun 5, 2009 | 02:07 PM
love you guys, thanks for all the advise and comments. great place and always lots of advises. coooool.
^_______^
RevMeHarder
Jun 1, 2026 02:30 PM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
tgaffner
Sep 7, 2015 08:49 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
