View Full Version : strut bar removal
cardinal35
12-29-2003, 02:52 PM
Does anyone know if the strut bar in the engine bay is attached with some kind of threadlock on the bolts? and if I remove it will I need to get more thread lock to put it back on?
mikeb
12-29-2003, 03:11 PM
no, you can remove it easily
its just two bolts on each side
cardinal35
12-29-2003, 03:15 PM
thank you :) I was afraid to try and then screw up something- I really doubt these things can drive without one
wakeech
12-29-2003, 07:04 PM
...why would you say that?
syntrix
12-29-2003, 09:44 PM
If I remember correctly, it's a 12mm nut.
13-19.5 ft-lbs
Samyv
12-30-2003, 07:37 AM
If your looking to replace it you should check out the thread titled thanks under the Canadian forum. You will find a picture of a Triangular strut bar from cpracing. I had the mod installed on my car--what a difference in handling. You can order one at cpracing.ca. It's easy to install.
cardinal35
12-30-2003, 07:45 AM
"...why would you say that?" .......being winter-I don't need even the most minute loss of control
wakeech
12-30-2003, 09:10 AM
oh, it's just an ancillary structural peice, which benefits your suspension under only the heaviest load. so, in winter especially (with the low speeds everywhere), it's not a big deal if you had to leave it off :)
cardinal35
12-30-2003, 09:44 AM
wakeech- thanks! I was worried about getting my timing right to get it back on before I drove it to work- now I am in the cool- thanx for the response- your advice is always heeded with the upmost respect
