Your "One time only" problems..?
Old May 27, 2009 | 11:46 AM
CyberPitz's Avatar
Huge hole is huge
Post what happened to your car just once and required no real fixing to resolve...could be anything from a rattle to an odd electronics failure to a no start even!
I got into my car, just like any other day. Went to start her up, just about a flat battery. I remembered activating the alarm on the car, so it wasn't a door open. I look all around, trying to find some light that was stuck on, nothing. It was about 3 days since I had driven the car, so whatever drained it had all weekend. I went and got the jumper cables and hooked her up. Started up just fine and that was the last time it had that issue. I was left scratching my head at what caused it.
Old May 27, 2009 | 11:51 AM
Hidef1080's Avatar
RX Lectriod from Planet 8
None for me so far.
A tad over 3 weeks and 1000 miles of smiles.
I just wanted to be a post ho.....
Old May 27, 2009 | 11:53 AM
CyberPitz's Avatar
Huge hole is huge
Originally Posted by Hidef1080
None for me so far.
Don't we all?
The only other issue that I've had with the car is the cover behind the wheel rotors bent in and was touching so when I drive a hideous squeel came out of the wheel well. Nothing to do with the cars issue, at least!
*knocks on wood*
Old May 27, 2009 | 03:29 PM
delhi's Avatar
Grand Chancellor
My DSC and ABS light came on. But the car drove fine. The next time I restarted the car, the lights went away. The car seems to feel stronger now. And gas mileage kicks ***. Maybe it met Jesus?
Old May 27, 2009 | 03:33 PM
myriadshalaks's Avatar
rot8ing
strange clicking from driver's side front even at idle.
bottom front plug wire was dangling in the breeze.
Old May 27, 2009 | 03:52 PM
The Drunk IT Guy's Avatar
I just shat myself
There was a high pitched squeal that came from under the dash, pitch raised/lowered with the RPM. Sounded a lot like a turbo, a bit higher though. Came and went twice but I haven't heard it in over a year.
Old May 27, 2009 | 03:55 PM
Spinning Sushi's Avatar
I <3 Sushi
I had this weird problem. The car was sitting at the stop light at idle, then all of a sudden, it just redlined without me stepping on the throttle. It was bouncing off of it and it seriously freaked me out so I killed the ignition, restarted the car, and it was fine. It was the weirdest two seconds of my life.
Old May 27, 2009 | 06:24 PM
This babe washed my car!
Old May 27, 2009 | 06:46 PM
yale02's Avatar
Still plays with cars
Idle dipped to the lowest marker and back up. A/C not on, mid 70's ambient temps...
Old May 27, 2009 | 06:49 PM
Burton's Avatar
Rotary Rambler
I had a metallic sound of scraping off my drivers side. Spent HOURS trying to find the cause but no one else could hear it... Turned out a rock was wedged between the metal air director thing and the rotor...
Old May 27, 2009 | 07:31 PM
2tone's Avatar
The RX-8 is missed
just had this happen...
on a 3-hour drive, my coolant level light would come on for a few minutes, then go out for a few, etc. for pretty much the entire 3 hour. that was this weekend...om said it's not good and to take it in immediately...i was going to take it in tuesday but all day tuesday and today to/from work...never came on again. not sure what would cause that issue, but so far i'm at a loss...
Old May 27, 2009 | 07:48 PM
rot8ing
2tone, there's a tsb for the coolant tank. the sensors are bad. your dealer should replace it for free if you have any warranty left.
Old May 27, 2009 | 08:00 PM
nadaxsurf720's Avatar
lmao!!! dude, that IS meeting jesus! if only mazda couldve partnered with jesus to do something better with gas mileage and hp increase....
after replacing my ignition coils, my car stalled one time 2 days after.... but to this day it hasnt stalled again!
the only other incident i had like that was i thought my passenger side window was broken because it wouldnt go back up... for 2 days my window was down (even bagging it to prevent rain from getting inside and driving with a bag!!!) and i had no idea wtf it was i thought the window motor might've died or something..
this being my first car with power options, i didnt realize there was a window lock!!!
Old May 27, 2009 | 08:18 PM
PSTNLSS's Avatar
The Former PSNTLSS
I got decent gas mileage
Old May 27, 2009 | 08:35 PM
2tone's Avatar
The RX-8 is missed
hmm, interesting. no warranty left but at least if it's just a sensor thing, they i'll worry less about it. thanks myriad!!
Old May 27, 2009 | 08:50 PM
cjkim's Avatar
^noob
wow me too! i've hit 24.x mpg once! it was weird...
Old May 28, 2009 | 11:47 AM
CyberPitz's Avatar
Huge hole is huge
Completely different, but my 88 RX-7 did that a few times to me. I'd be driving down the road and it would just start reving, I checked and the throttle cable was never sticking or anything. In the end, it went away and I never saw it again. Crazy automobiles.
Old May 28, 2009 | 12:25 PM
greg985's Avatar
The 337
damn that is wild
Old May 28, 2009 | 12:39 PM
renesisgenesis's Avatar
mod edit
once i stalled while doing a second gear power slide. Went all the way around and didn't give it enough throttle and it killed it as I was going backwards.
uZu
Dec 30, 2015 12:35 PM
tigg.z
Aug 26, 2015 09:51 PM
GrAfiX
Aug 24, 2015 08:08 AM
arjunmshah
Aug 6, 2015 10:56 AM
dbarber
Jul 25, 2015 01:34 PM
